ONTAP SAN Host Utilities
NVMe-oF host configuration for RHEL 8.7 with ONTAP
Contributors netapp-ranuk netapp-pcarriga netapp-sarajane
NVMe over Fabrics or NVMe-oF (including NVMe/FC and other transports) is supported with Red Hat Enterprise Linux (RHEL) 8.7 with ANA (Asymmetric Namespace Access). ANA is the asymmetric logical unit access (ALUA) equivalent in the NVMe-oF environment, and is currently implemented with in-kernel NVMe Multipath. During this procedure, you enable NVMe-oF with in-kernel NVMe Multipath using ANA on RHEL 8.7 and ONTAP as the target.
See the Interoperability Matrix Tool for accurate details regarding supported configurations.
Features
RHEL 8.7 includes support for NVMe/TCP (as a Technology Preview feature) in addition to NVMe/FC. The NetApp plugin in the native nvme-cli package is capable of displaying ONTAP details for both NVMe/FC and NVMe/TCP namespaces.
Known limitations
  • For RHEL 8.7, in-kernel NVMe multipath remains disabled by default. Therefore, you need to enable it manually.
  • NVMe/TCP on RHEL 8.7 remains a Technology Preview feature due to open issues. Refer to the RHEL 8.7 release notes for details.
  • SAN booting using the NVMe-oF protocol is currently not supported.
Enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Before you begin
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Steps
  1. Create a SAN boot namespace and map it to the host.
  2. Enable SAN booting in the server BIOS for the ports to which the SAN boot LUN is mapped.
    For information on how to enable the HBA BIOS, see your vendor-specific documentation.
  3. Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Enable in-kernel NVMe Multipath
You can use the following procedure to enable in-kernel NVMe multipath.
Steps
  1. Install RHEL 8.7 on the server.
  2. After the installation is complete, verify that you are running the specified RHEL 8.7 kernel. See the Interoperability Matrix Tool for the current list of supported versions.
    Example:
    # uname -r
    4.18.0-425.3.1.el8.x86_64
  3. Install the nvme-cli package:
    Example:
    # rpm -qa|grep nvme-cli
    nvme-cli-1.16-5.el8.x86_64
  4. Enable in-kernel NVMe multipath:
    Example
    # grubby --args=nvme_core.multipath=Y --update-kernel
    /boot/vmlinuz-4.18.0-425.3.1.el8.x86_64
  5. On the host, check the host NQN string at /etc/nvme/hostnqn and verify that it matches the host NQN string for the corresponding subsystem on the ONTAP array. Example:
    # cat /etc/nvme/hostnqn
              nqn.2014-08.org.nvmexpress:uuid:a7f7a1d4-311a-11e8-b634-            7ed30aef10b7
    ::> vserver nvme subsystem host show -vserver vs_nvme167
    Vserver     Subsystem       Host NQN
    vs_nvme167 rhel_167_LPe35002  nqn.2014-08.org.nvmexpress:uuid: a7f7a1d4-311a-11e8-b634-7ed30aef10b7
    Note If the host NQN strings do not match, you should use the vserver modify command to update the host NQN string on your corresponding ONTAP NVMe subsystem to match the host NQN string /etc/nvme/hostnqn on the host.
  6. Reboot the host.
    Note
    If you intend to run both NVMe and SCSI co-existent traffic on the same host, NetApp recommends using in-kernel NVMe multipath for ONTAP namespaces and dm-multipath for ONTAP LUNs respectively. This means that the ONTAP namespaces should be excluded from dm-multipath to prevent dm-multipath from claiming these namespace devices. You can do this by adding the enable_foreign setting to the /etc/multipath.conf file:
    # cat /etc/multipath.conf
    defaults {
            enable_foreign     NONE
    Restart the multipathd daemon by running a systemctl restart multipathd command to allow the new setting to take effect.
Configure NVMe/FC
You can configure NVMe/FC for Broadcom/Emulex or Marvell/Qlogic adapters.
Broadcom/Emulex
Steps
  1. Verify that you are using the supported adapter. See the Interoperability Matrix Tool for the current list of supported adapters.
    # cat /sys/class/scsi_host/host*/modelname
    LPe35002-M2
    LPe35002-M2
    # cat /sys/class/scsi_host/host*/modeldesc
    Emulex LightPulse LPe35002-M2 2-Port 32Gb Fibre Channel Adapter
  2. Verify that you are using the recommended Broadcom lpfc firmware and inbox driver. See the Interoperability Matrix Tool for the current list of supported adapter driver and firmware versions.
    # cat /sys/class/scsi_host/host*/fwrev
    14.0.505.12, sli-4:6:d
    # cat /sys/module/lpfc/version
    0:14.0.0.15
  3. Verify that lpfc_enable_fc4_type is set to 3
    # cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type
    3
  4. Verify that the initiator ports are up and running, and that you can see the target LIFs.
    # cat /sys/class/fc_host/host*/port_name
    0x100000109b95467c
    0x100000109b95467b
    # cat /sys/class/fc_host/host*/port_state
    Online
    Online
    # cat /sys/class/scsi_host/host*/nvme_info
    NVME Initiator Enabled
    XRI Dist lpfc1 Total 6144 IO 5894 ELS 250
    NVME LPORT lpfc1 WWPN x100000109b95467c WWNN x200000109b95467c DID x0a1500 ONLINE
    NVME RPORT       WWPN x2071d039ea36a105 WWNN x206ed039ea36a105 DID x0a0907 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x2072d039ea36a105 WWNN x206ed039ea36a105 DID x0a0805 TARGET DISCSRVC ONLINE
    NVME Statistics
    LS: Xmt 00000001c7 Cmpl 00000001c7 Abort 00000000
    LS XMIT: Err 00000000  CMPL: xb 00000000 Err 00000000
    Total FCP Cmpl 0000000004909837 Issue 0000000004908cfc OutIO fffffffffffff4c5
    abort 0000004a noxri 00000000 nondlp 00000458 qdepth 00000000 wqerr 00000000 err 00000000
    FCP CMPL: xb 00000061 Err 00017f43
    XRI Dist lpfc0 Total 6144 IO 5894 ELS 250
    NVME LPORT lpfc0 WWPN x100000109b95467b WWNN x200000109b95467b DID x0a1100 ONLINE
    NVME RPORT       WWPN x2070d039ea36a105 WWNN x206ed039ea36a105 DID x0a1007 TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x206fd039ea36a105 WWNN x206ed039ea36a105 DID x0a0c05 TARGET DISCSRVC ONLINE
    NVME Statistics
    Total FCP Cmpl 0000000004909464 Issue 0000000004908531 OutIO fffffffffffff0cd
    abort 0000004f noxri 00000000 nondlp 00000361 qdepth 00000000 wqerr 00000000 err 00000000
    FCP CMPL: xb 0000006b Err 00017f99
Marvell/QLogic FC adapter for NVMe/FC
The native inbox qla2xxx driver included in the RHEL 8.7 kernel has the latest fixes. These fixes are essential for ONTAP support.
Steps
  1. Verify that you are running the supported adapter driver and firmware versions using the following command:
    # cat /sys/class/fc_host/host*/symbolic_name
    QLE2772 FW:v9.08.02 DVR:v10.02.07.400-k-debug
  2. Verify ql2xnvmeenable is set, which enables the Marvell adapter to function as a NVMe/FC initiator using the following command:
    # cat /sys/module/qla2xxx/parameters/ql2xnvmeenable
    1
Enable 1MB I/O (Optional)
ONTAP reports an MDTS (Max Data Transfer Size) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
Note These steps don't apply to Qlogic NVMe/FC hosts.
Steps
  1. Set the lpfc_sg_seg_cnt parameter to 256:
    cat /etc/modprobe.d/lpfc.conf
    You should see an output similar to the following example:
    options lpfc lpfc_sg_seg_cnt=256
  2. Run the dracut -f command, and reboot the host.
  3. Verify that the value for lpfc_sg_seg_cnt is 256:
    cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Configure NVMe/TCP
NVMe/TCP does not have auto-connect functionality. Therefore, if a path goes down and is not reinstated within the default time out period of 10 minutes, NVMe/TCP cannot automatically reconnect. To prevent a time out, you should set the retry period for failover events to at least 30 minutes.
Steps
  1. Verify whether the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
    # nvme discover -t tcp -w 192.168.211.5 -a 192.168.211.14
    Discovery Log Number of Records 8, Generation counter 10
    =====Discovery Log Entry 0======
    trtype:  tcp
    adrfam:  ipv4
    subtype: unrecognized
    treq:    not specified
    portid:  0
    trsvcid: 8009
    subnqn:  nqn.199208.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:discovery
    traddr:  192.168.211.15
    sectype: none
    =====Discovery Log Entry 1======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  1
    trsvcid: 8009
    subnqn:  nqn.1992-08.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:discovery
    traddr:  192.168.111.15
    sectype: none
    =====Discovery Log Entry 2======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  2
    trsvcid: 8009
    traddr:  192.168.211.14
    sectype: none
    =====Discovery Log Entry 3======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  3
    trsvcid: 8009
    traddr:  192.168.111.14
    sectype: none
    =====Discovery Log Entry 4======
    trtype:  tcp
    adrfam:  ipv4
    subtype: nvme subsystem
    treq:    not specified
    portid:  0
    trsvcid: 4420
    subnqn:  nqn.1992-08.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:subsystem.rhel_tcp_165
    sectype: none
    =====Discovery Log Entry 5======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  1
    trsvcid: 4420
    sectype: none
    =====Discovery Log Entry 6======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  2
    trsvcid: 4420
    sectype: none
    =====Discovery Log Entry 7======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
       portid:  3
    trsvcid: 4420
    sectype: none
    [root@R650-13-79 ~]#
  2. Verify that other NVMe/TCP initiator-target LIF combos can successfully fetch discovery log page data. For example:
    # nvme discover -t tcp -w 192.168.211.5 -a 192.168.211.15
    # nvme discover -t tcp -w 192.168.111.5 -a 192.168.111.14
    # nvme discover -t tcp -w 192.168.111.5 -a 192.168.111.15
  3. Run nvme connect-all command across all the supported NVMe/TCP initiator-target LIFs across the nodes. Ensure you set a longer ctrl_loss_tmo timer retry period (for example, 30 minutes, which can be set through -l 1800) during the connect-all so that it would retry for a longer period of time in the event of a path loss. For example:
    # nvme connect-all -t tcp -w 192.168.211.5-a 192.168.211.14 -l 1800
    # nvme connect-all -t tcp -w 192.168.211.5 -a 192.168.211.15 -l 1800
    # nvme connect-all -t tcp -w 192.168.111.5 -a 192.168.111.14 -l 1800
    # nvme connect-all -t tcp -w 192.168.111.5 -a 192.168.111.15 -l 1800
Validate NVMe-oF
You can use the following procedure to validate NVMe-oF.
Steps
  1. Verify that in-kernel NVMe multipath is indeed enabled by checking:
    # cat /sys/module/nvme_core/parameters/multipath
    Y
  2. Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces properly reflect on the host:
    # cat /sys/class/nvme-subsystem/nvme-subsys*/model
    # cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy
    round-robin
    round-robin
  3. Verify that the ONTAP namespaces properly reflect on the host. For example:
    # nvme list
    Node           SN                    Model                   Namespace
    /dev/nvme0n1   81Gx7NSiKSRNAAAAAAAB   NetApp ONTAP Controller   1
    Usage                Format         FW Rev
    21.47  GB /  21.47  GB  4 KiB + 0 B    FFFFFFFF
  4. Verify that the controller state of each path is live and has proper ANA status. For example:
    # nvme list-subsys /dev/nvme1n1
    nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:subsystem.rhel_tcp_165
     +- nvme0 tcp traddr=192.168.211.15 trsvcid=4420 host_traddr=192.168.211.5 live non-optimized
     +- nvme1 tcp traddr=192.168.211.14 trsvcid=4420 host_traddr=192.168.211.5 live optimized
     +- nvme2 tcp traddr=192.168.111.15 trsvcid=4420 host_traddr=192.168.111.5 live non-optimized
     +- nvme3 tcp traddr=192.168.111.14 trsvcid=4420 host_traddr=192.168.111.5 live optimized
  5. Verify that the NetApp plug-in displays proper values for each ONTAP namespace device. For example:
    # nvme netapp ontapdevices -o column
    Device       Vserver          Namespace Path
    /dev/nvme0n1 vs_tcp79     /vol/vol1/ns1
    NSID  UUID                                   Size
    1     79c2c569-b7fa-42d5-b870-d9d6d7e5fa84  21.47GB
    # nvme netapp ontapdevices -o json
      "ONTAPdevices" : [
          "Device" : "/dev/nvme0n1",
          "Vserver" : "vs_tcp79",
          "Namespace_Path" : "/vol/vol1/ns1",
          "NSID" : 1,
          "UUID" : "79c2c569-b7fa-42d5-b870-d9d6d7e5fa84",
          "Size" : "21.47GB",
          "LBA_Data_Size" : 4096,
          "Namespace_Size" : 5242880
Known issues
The NVMe-oF host configuration for RHEL 8.7 with ONTAP has the following known issues:
NetApp Bug ID Title Description
1479047
RHEL 8.7 NVMe-oF hosts create duplicate Persistent Discovery Controllers
On NVMe over Fabrics (NVMe-oF) hosts, you can use the "nvme discover -p" command to create Persistent Discovery Controllers (PDCs). When this command is used, only one PDC should be created per initiator-target combination. However, if you are running ONTAP 9.10.1 and Red Hat Enterprise Linux (RHEL) 8.7 with an NVMe-oF host, a duplicate PDC is created each time "nvme discover -p" is executed. This leads to unnecessary usage of resources on both the host and the target.
