ONTAP SAN Host Utilities
NVMe-oF host configuration for RHEL 8.8 with ONTAP
Contributors netapp-ranuk netapp-pcarriga netapp-sarajane
NVMe over Fabrics (NVMe-oF), including NVMe over Fibre Channel (NVMe/FC) and other transports, is supported with Red Hat Enterprise Linux (RHEL) 8.8 with Asymmetric Namespace Access (ANA). In NVMe-oF environments, ANA is the equivalent of ALUA multipathing in iSCSI and FC environments and is implemented with in-kernel NVMe multipath.
The following support is available for the NVMe-oF host configuration for RHEL 8.8 with ONTAP:
  • Support for NVMe over TCP (NVMe/TCP) in addition to NVMe/FC. The NetApp plug-in in the native nvme-cli package displays ONTAP details for both NVMe/FC and NVMe/TCP namespaces.
For additional details on supported configurations, see the Interoperability Matrix Tool.
Known limitations
  • In-kernel NVMe multipath is disabled by default for RHEL 8.8 NVMe-oF hosts. Therefore, you need to enable it manually.
  • On RHEL 8.8 hosts, NVMe/TCP is a technology preview feature due to open issues.
  • SAN booting using the NVMe-oF protocol is currently not supported.
Enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Before you begin
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Steps
  1. Create a SAN boot namespace and map it to the host.
  2. Enable SAN booting in the server BIOS for the ports to which the SAN boot LUN is mapped.
    For information on how to enable the HBA BIOS, see your vendor-specific documentation.
  3. Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Enable in-kernel multipath
You can use the following procedure to enable in-kernal multipath.
Steps
  1. Install RHEL 8.8 on the host server.
  2. After the installation is complete, verify that you are running the specified RHEL 8.8 kernel.
    # uname -r
    Example output
    4.18.0-477.10.1.el8_8.x86_64
  3. Install the nvme-cli package:
    rpm -qa|grep nvme-cli
    Example output
    nvme-cli-1.16-7.el8.x86_64
  4. Enable in -kernel NVMe multipath:
    # grubby --args=nvme_core.multipath=Y --update-kernel /boot/vmlinuz-4.18.0-477.10.1.el8_8.x86_64
  5. On the host, check the host NQN string at /etc/nvme/hostnqn:
    # cat /etc/nvme/hostnqn
    Example output
    nqn.2014-08.org.nvmexpress:uuid:f6517cae-3133-11e8-bbff-7ed30aef123f
  6. Verify that the hostnqn string matches the hostnqn string for the corresponding subsystem on the ONTAP array:
    ::> vserver nvme subsystem host show -vserver vs_fcnvme_141
    Example output
    Vserver     Subsystem       Host NQN
    vs_nvme161 rhel_161_LPe32002    nqn.2014-08.org.nvmexpress:uuid:f6517cae-3133-11e8-bbff-7ed30aef123f
    Note If the host NQN strings do not match, you can use the vserver modify command to update the host NQN string on your corresponding ONTAP NVMe subsystem to match the host NQN string /etc/nvme/hostnqn on the host.
  7. Reboot the host.
Note
If you intend to run both NVMe and SCSI co-existent traffic on the same host, NetApp recommends using the in-kernel NVMe multipath for ONTAP namespaces and dm-multipath for ONTAP LUNs respectively. This means that the ONTAP namespaces should be excluded from dm-multipath to prevent dm-multipath from claiming these namespace devices. This can be done by adding the enable_foreign setting to the /etc/multipath.conf file:
# cat /etc/multipath.conf
defaults {
  enable_foreign  NONE
Configure NVMe/FC
You can configure NVMe/FC for Broadcom/Emulex or Marvell/Qlogic adapters.
Broadcom/Emulex
Steps
  1. Verify that you are using the supported adapter model:
    # cat /sys/class/scsi_host/host*/modelname
    Example output:
    LPe32002-M2
    LPe32002-M2
    # cat /sys/class/scsi_host/host*/modeldesc
    Example output:
    Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
  2. Verify that you are using the recommended Broadcom lpfc firmware and inbox driver:
    # cat /sys/class/scsi_host/host*/fwrev
    14.0.639.18, sli-4:2:c
    # cat /sys/module/lpfc/version
    0:14.0.0.18
    For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
  3. Verify that lpfc_enable_fc4_type is set to 3:
    # cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type
    3
  4. Verify that the initiator ports are up and running and that you can see the target LIFs:
    # cat /sys/class/fc_host/host*/port_name
    0x100000109b1c1204
    0x100000109b1c1205
    # cat /sys/class/fc_host/host*/port_state
    Online
    Online
    # cat /sys/class/scsi_host/host*/nvme_info NVME Initiator Enabled
    XRI Dist lpfc0 Total 6144 IO 5894 ELS 250
    NVME LPORT lpfc0 WWPN x10000090fae0ec88 WWNN x20000090fae0ec88 DID x0a1300 ONLINE
    NVME RPORT       WWPN x2049d039ea36a105 WWNN x2048d039ea36a105 DID x0a0c0a TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x204bd039ea36a105 WWNN x2048d039ea36a105 DID x0a100a TARGET DISCSRVC ONLINE
    NVME Statistics
    LS: Xmt 0000000134 Cmpl 0000000134 Abort 00000000
    LS XMIT: Err 00000000  CMPL: xb 00000000 Err 00000000
    Total FCP Cmpl 000000000825e567 Issue 000000000825d7ed OutIO fffffffffffff286
    abort 0000027c noxri 00000000 nondlp 00000a02 qdepth 00000000 wqerr 00000000 err 00000000
    FCP CMPL: xb 00000782 Err 000130fa
    XRI Dist lpfc1 Total 6144 IO 5894 ELS 250
    NVME LPORT lpfc1 WWPN x10000090fae0ec89 WWNN x20000090fae0ec89 DID x0a1200 ONLINE
    NVME RPORT       WWPN x204ad039ea36a105 WWNN x2048d039ea36a105 DID x0a080a TARGET DISCSRVC ONLINE
    NVME RPORT       WWPN x204cd039ea36a105 WWNN x2048d039ea36a105 DID x0a090a TARGET DISCSRVC ONLINE
    NVME Statistics
    Total FCP Cmpl 000000000826ced5 Issue 000000000826c226 OutIO fffffffffffff351
            abort 0000029d noxri 00000000 nondlp 000008df qdepth 00000000 wqerr 00000000 err 00000000
    FCP CMPL: xb 00000821 Err 00012fcd
Marvell/QLogic FC Adapter for NVMe/FC
The native inbox qla2xxx driver included in the RHEL 8.8 GA kernel has the latest upstream fixes. These fixes are essential for ONTAP support.
Steps
Verify that you are running the supported adapter driver and firmware versions:
# cat /sys/class/fc_host/host*/symbolic_name
Example output
QLE2772 FW:v9.10.11 DVR:v10.02.07.900-k-debug
  1. Verify that ql2xnvmeenable is set. This enables the Marvell adapter to function as an NVMe/FC initiator:
    # cat /sys/module/qla2xxx/parameters/ql2xnvmeenable
    1
Enable 1MB I/O (Optional)
ONTAP reports an MDTS (Max Data Transfer Size) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
Note These steps don't apply to Qlogic NVMe/FC hosts.
Steps
  1. Set the lpfc_sg_seg_cnt parameter to 256:
    cat /etc/modprobe.d/lpfc.conf
    You should see an output similar to the following example:
    options lpfc lpfc_sg_seg_cnt=256
  2. Run the dracut -f command, and reboot the host.
  3. Verify that the value for lpfc_sg_seg_cnt is 256:
    cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Configure NVMe/TCP
NVMe/TCP does not have auto-connect functionality. Therefore, if a path goes down and is not reinstated within the default time out period of 10 minutes, NVMe/TCP cannot automatically reconnect. To prevent a time out, you should set the retry period for failover events to at least 30 minutes.
Steps
  1. Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
    nvme discover -t tcp -w host-traddr -a traddr
    Example output:
    # nvme discover -t tcp -w 192.168.111.79 -a 192.168.111.14
    Discovery Log Number of Records 8, Generation counter 10
    =====Discovery Log Entry 0======
    trtype:  tcp
    adrfam:  ipv4
    subtype: unrecognized
    treq:    not specified
    portid:  0
    trsvcid: 8009
    subnqn:  nqn.1992-08.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:discovery
    traddr:  192.168.211.15
    sectype: none
    =====Discovery Log Entry 1======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  1
    trsvcid: 8009
    traddr:  192.168.111.15
    sectype: none
    =====Discovery Log Entry 2======
    trtype:  tcp
    adrfam:  ipv4
    treq:    not specified
    portid:  2
    trsvcid: 8009
    traddr:  192.168.211.14
    sectype: none
  2. Verify that the other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
    Example output:
    # nvme	discover	-t   tcp    -w	192.168.111.79   -a	192.168.111.15
    # nvme	discover	-t   tcp    -w	192.168.211.79   -a	192.168.211.14
    # nvme	discover	-t   tcp    -w	192.168.211.79   -a	192.168.211.15
  3. Run the nvme connect-all command across all the supported NVMe/TCP initiator-target LIFs across the nodes, and set the controller loss timeout period for at least 30 minutes or 1800 seconds:
    nvme connect-all -t tcp -w host-traddr -a traddr -l 1800
    Example output:
    # nvme	connect-all	-t	tcp	-w	192.168.111.79	-a	192.168.111.14	-l	1800
    # nvme	connect-all	-t	tcp	-w	192.168.111.79	-a	192.168.111.15	-l	1800
    # nvme	connect-all	-t	tcp	-w	192.168.211.79	-a	192.168.211.14	-l	1800
    # nvme	connect-all	-t	tcp	-w	192.168.211.79	-a	192.168.211.15	-l	1800
Validate NVMe-oF
You can use the following procedure to validate NVME-oF.
Steps
  1. Verify that the in-kernel NVMe multipath is enabled:
    # cat /sys/module/nvme_core/parameters/multipath
    Y
  2. Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
    # cat /sys/class/nvme-subsystem/nvme-subsys*/model
    # cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy
    round-robin
    round-robin
  3. Verify that the namespaces are created and correctly discovered on the host:
    # nvme list
    Example output:
    Node         SN                   Model
    /dev/nvme3n1 81Gx7NSiKSQeAAAAAAAB	NetApp ONTAP Controller
    Namespace Usage    Format             FW             Rev
    1                 21.47 GB / 21.47 GB	4 KiB + 0 B   FFFFFFFF
  4. Verify that the controller state of each path is live and has the correct ANA status:
    NVMe/FC
    # nvme list-subsys /dev/nvme3n1
    Example output:
    nvme-subsys3 - NQN=nqn.1992-08.com.netapp:sn.ab4fa6a5ba8b11ecbe3dd039ea359e4b:subsystem.rhel_161_Lpe32002
     +- nvme0 fc traddr=nn-0x2048d039ea36a105:pn-0x204cd039ea36a105 host_traddr=nn-0x20000090fae0ec89:pn-0x10000090fae0ec89 live non-optimized
     +- nvme1 fc traddr=nn-0x2048d039ea36a105:pn-0x204ad039ea36a105 host_traddr=nn-0x20000090fae0ec89:pn-0x10000090fae0ec89 live optimized
     +- nvme2 fc traddr=nn-0x2048d039ea36a105:pn-0x204bd039ea36a105 host_traddr=nn-0x20000090fae0ec88:pn-0x10000090fae0ec88 live non-optimized
     +- nvme4 fc traddr=nn-0x2048d039ea36a105:pn-0x2049d039ea36a105 host_traddr=nn-0x20000090fae0ec88:pn-0x10000090fae0ec88 live optimized
    NVMe/TCP
    # nvme list-subsys /dev/nvme0n1
    Example output:
    nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.154a5833c78c11ecb069d039ea359e4b:subsystem.rhel_tcp_165
     +- nvme0 tcp traddr=192.168.111.15 trsvcid=4420 host_traddr=192.168.111.79 live non-optimized
     +- nvme1 tcp traddr=192.168.111.14 trsvcid=4420 host_traddr=192.168.111.79 live optimized
     +- nvme2 tcp traddr=192.168.211.15 trsvcid=4420 host_traddr=192.168.211.79 live non-optimized
  5. Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
    Column
    # nvme netapp ontapdevices -o column
    Example output:
    Device        Vserver   Namespace Path
    /dev/nvme0n1 vs_tcp           /vol/vol1/ns1
    NSID       UUID                                   Size
    1          338d73ce-b5a8-4847-9cc9-b127c75d8855	21.47GB
    JSON
    # nvme netapp ontapdevices -o json
    Example output
      "ONTAPdevices" : [
          "Device" : "/dev/nvme0n1",
          "Vserver" : "vs_tcp79",
          "Namespace_Path" : "/vol/vol1/ns1",
          "NSID" : 1,
          "UUID" : "338d73ce-b5a8-4847-9cc9-b127c75d8855",
          "Size" : "21.47GB",
          "LBA_Data_Size" : 4096,
          "Namespace_Size" : 5242880
Known issues
The NVMe-oF host configuration for RHEL 8.8 with ONTAP release has the following known issues:
NetApp Bug ID Title Description
1479047
RHEL 8.8 NVMe-oF hosts create duplicate persistent discovery controllers
On NVMe over Fabrics (NVMe-oF) hosts, you can use the "nvme discover -p" command to create Persistent Discovery Controllers (PDCs). When this command is used, only one PDC should be created per initiator-target combination. However, if you are running Red Hat Enterprise Linux (RHEL) 8.8 on an NVMe-oF host, a duplicate PDC is created each time "nvme discover -p" is executed. This leads to unnecessary usage of resources on both the host and the target.
