NVMe-oF host configuration for RHEL 9.2 with ONTAP
NVMe over Fabrics (NVMe-oF), including NVMe over Fibre Channel (NVMe/FC) and other transports, is supported with Red Hat Enterprise Linux (RHEL) 9.2 with Asymmetric Namespace Access (ANA). In NVMe-oF environments, ANA is the equivalent of ALUA multipathing in iSCSI and FC environments and is implemented with in-kernel NVMe multipath.
The following support is available for the NVMe-oF host configuration for RHEL 9.2 with ONTAP:
Support for NVMe over TCP (NVMe/TCP) in addition to NVMe/FC. The NetApp plug-in in the native nvme-cli package displays ONTAP details for both NVMe/FC and NVMe/TCP namespaces.
Use of NVMe and SCSI co-existent traffic on the same host on a given host bus adapter (HBA), without the explicit dm-multipath settings to prevent claiming NVMe namespaces.
For additional details on supported configurations, see the Interoperability Matrix Tool.
Features
RHEL 9.2 has in-kernel NVMe multipath enabled for NVMe namespaces by default, therefore, there is no need for explicit settings.
Known limitations
SAN booting using the NVMe-oF protocol is currently not supported.
Enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Create a SAN boot namespace and map it to the host.
Enable SAN booting in the server BIOS for the ports to which the SAN boot LUN is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Validate software versions
You can use the following procedure to validate the minimum supported RHEL 9.2 software versions.
Install RHEL 9.2 on the server. After the installation is complete, verify that you are running the specified RHEL 9.2 kernel.
# uname -r
Example output:
5.14.0-284.11.1.el9_2.x86_64
Install the
nvme-cli
package:# rpm -qa|grep nvme-cli
Example output:
nvme-cli-2.2.1-2.el9.x86_64
Install the
libnvme
package:#rpm -qa|grep libnvme
Example output
libnvme-1.2-2.el9.x86_64
On the RHEL 9.2 host, check the hostnqn string at
/etc/nvme/hostnqn
:# cat /etc/nvme/hostnqn
Example output
nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0032-3310-8033-b8c04f4c5132
Verify that the
hostnqn
string matches thehostnqn
string for the corresponding subsystem on the ONTAP array:::> vserver nvme subsystem host show -vserver vs_ol_nvme
Example output:
Vserver Subsystem Host NQN ----------- --------------- ---------------------------------------------------------- vs_nvme207 rhel_207_LPe32002 nqn.2014-08.org.nvmexpress:uuid:325e7554-1f9b-11ec-8489-3a68dd61a4df
If the hostnqn
strings do not match, use thevserver modify
command to update thehostnqn
string on your corresponding ONTAP array subsystem to match thehostnqn
string from/etc/nvme/hostnqn
on the host.
Configure NVMe/FC
You can configure NVMe/FC for Broadcom/Emulex or Marvell/Qlogic adapters.
Verify that you are using the supported adapter model.
# cat /sys/class/scsi_host/host*/modelname
Example output:
LPe32002-M2 LPe32002-M2
# cat /sys/class/scsi_host/host*/modeldesc
Example output:
Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfc
firmware and inbox driver.# cat /sys/class/scsi_host/host*/fwrev 14.0.639.18, sli-4:2:c 14.0.639.18, sli-4:2:c # cat /sys/module/lpfc/version 0:12.8.0.11
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that
lpfc_enable_fc4_type
is set to3
:# cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type 3
Verify that the initiator ports are up and running and that you can see the target LIFs:
# cat /sys/class/fc_host/host*/port_name 0x100000109b1c1204 0x100000109b1c1205
# cat /sys/class/fc_host/host*/port_state Online Online
# cat /sys/class/scsi_host/host*/nvme_info NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109b1c1204 WWNN x200000109b1c1204 DID x011d00 ONLINE NVME RPORT WWPN x203800a098dfdd91 WWNN x203700a098dfdd91 DID x010c07 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203900a098dfdd91 WWNN x203700a098dfdd91 DID x011507 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000f78 Cmpl 0000000f78 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000002fe29bba Issue 000000002fe29bc4 OutIO 000000000000000a abort 00001bc7 noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00001e15 Err 0000d906 NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109b1c1205 WWNN x200000109b1c1205 DID x011900 ONLINE NVME RPORT WWPN x203d00a098dfdd91 WWNN x203700a098dfdd91 DID x010007 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203a00a098dfdd91 WWNN x203700a098dfdd91 DID x012a07 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000fa8 Cmpl 0000000fa8 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000002e14f170 Issue 000000002e14f17a OutIO 000000000000000a abort 000016bb noxri 00000000 nondlp 00000000 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00001f50 Err 0000d9f8
The native inbox qla2xxx driver included in the RHEL 9.2 GA kernel has the latest upstream fixes. These fixes are essential for ONTAP support.
Verify that you are running the supported adapter driver and firmware versions:
# cat /sys/class/fc_host/host*/symbolic_name
Example output
QLE2742 FW:v9.08.02 DVR:v10.02.00.106-k QLE2742 FW:v9.08.02 DVR:v10.02.00.106-k
Verify that
ql2xnvmeenable
is set. This enables the Marvell adapter to function as an NVMe/FC initiator:# cat /sys/module/qla2xxx/parameters/ql2xnvmeenable 1
Enable 1MB I/O (Optional)
ONTAP reports an MDTS (Max Data Transfer Size) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc
value of the lpfc_sg_seg_cnt
parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cnt
parameter to 256:cat /etc/modprobe.d/lpfc.conf
You should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -f
command, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cnt
is 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Configure NVMe/TCP
NVMe/TCP does not have auto-connect functionality. Therefore, if a path goes down and is not reinstated within the default time out period of 10 minutes, NVMe/TCP cannot automatically reconnect. To prevent a time out, you should set the retry period for failover events to at least 30 minutes.
Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w host-traddr -a traddr
Example output:
# nvme discover -t tcp -w 192.168.167.5 -a 192.168.167.22 Discovery Log Number of Records 8, Generation counter 18 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 0 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.c680f5bcae1411ed8639d039ea951c46:discovery traddr: 192.168.166.23 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 1 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.c680f5bcae1411ed8639d039ea951c46:discovery traddr: 192.168.166.22 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 2 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.c680f5bcae1411ed8639d039ea951c46:discovery traddr: 192.168.167.23 eflags: explicit discovery connections, duplicate discovery information sectype: none ..........
Verify that the other NVMe/TCP initiator-target LIF combinations are able to successfully fetch discovery log page data.
Example output:
#nvme discover -t tcp -w 192.168.166.5 -a 192.168.166.22 #nvme discover -t tcp -w 192.168.166.5 -a 192.168.166.23 #nvme discover -t tcp -w 192.168.167.5 -a 192.168.167.22 #nvme discover -t tcp -w 192.168.167.5 -a 192.168.167.23
Run the
nvme connect-all
command across all the supported NVMe/TCP initiator-target LIFs across the nodes, and set the controller loss timeout period for at least 30 minutes or 1800 seconds:nvme connect-all -t tcp -w host-traddr -a traddr -l 1800
Example output:
# nvme connect-all -t tcp -w 192.168.166.5 -a 192.168.166.22 -l 1800 # nvme connect-all -t tcp -w 192.168.166.5 -a 192.168.166.23 -l 1800 # nvme connect-all -t tcp -w 192.168.167.5 -a 192.168.167.22 -l 1800 # nvme connect-all -t tcp -w 192.168.167.5 -a 192.168.167.23 -l 1800
Validate NVMe-oF
You can use the following procedure to validate NVME-oF.
Verify that the in-kernel NVMe multipath is enabled:
# cat /sys/module/nvme_core/parameters/multipath Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
# cat /sys/class/nvme-subsystem/nvme-subsys*/model NetApp ONTAP Controller NetApp ONTAP Controller
# cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
# nvme list
Example output:
Node SN Model --------------------------------------------------------- /dev/nvme0n1 81CZ5BQuUNfGAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 21.47 GB / 21.47 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
NVMe/FC# nvme list-subsys /dev/nvme0n1
Example output:
nvme-subsys4 - NQN=nqn.1992-08.com.netapp:sn.8763d311b2ac11ed950ed039ea951c46:subsystem.rhel_207_LB \ +- nvme1 fc traddr=nn-0x20a6d039ea954d17:pn-0x20a7d039ea954d17,host_traddr=nn-0x200000109b1b95ef:pn-0x100000109b1b95ef live optimized +- nvme2 fc traddr=nn-0x20a6d039ea954d17:pn-0x20a8d039ea954d17,host_traddr=nn-0x200000109b1b95f0:pn-0x100000109b1b95f0 live optimized +- nvme3 fc traddr=nn-0x20a6d039ea954d17:pn-0x20aad039ea954d17,host_traddr=nn-0x200000109b1b95f0:pn-0x100000109b1b95f0 live non-optimized +- nvme5 fc traddr=nn-0x20a6d039ea954d17:pn-0x20a9d039ea954d17,host_traddr=nn-0x200000109b1b95ef:pn-0x100000109b1b95ef live non-optimized
NVMe/TCP# nvme list-subsys /dev/nvme1n1
Example output:
nvme-subsys1 - NQN=nqn.1992-08.com.netapp:sn.c680f5bcae1411ed8639d039ea951c46:subsystem.rhel_tcp97 \ +- nvme1 tcp traddr=192.168.167.23,trsvcid=4420,host_traddr=192.168.167.5 live non-optimized +- nvme2 tcp traddr=192.168.167.22,trsvcid=4420,host_traddr=192.168.167.5 live non-optimized +- nvme3 tcp traddr=192.168.166.23,trsvcid=4420,host_traddr=192.168.166.5 live optimized +- nvme4 tcp traddr=192.168.166.22,trsvcid=4420,host_traddr=192.168.166.5 live optimized
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Column# nvme netapp ontapdevices -o column
Example output:
Device Vserver Namespace Path ----------------------- ------------------------------ /dev/nvme0n1 vs_tcp /vol/vol1/ns1 NSID UUID Size ------------------------------------------------------------ 1 79c2c569-b7fa-42d5-b870-d9d6d7e5fa84 21.47GB
JSON# nvme netapp ontapdevices -o json
Example output
{ "ONTAPdevices" : [ { "Device" : "/dev/nvme0n1", "Vserver" : "vs_tcp79", "Namespace_Path" : "/vol/vol1/ns1", "NSID" : 1, "UUID" : "79c2c569-b7fa-42d5-b870-d9d6d7e5fa84", "Size" : "21.47GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 5242880 }, ] }
Known issues
There are no known issues.
