NVMe-oF host configuration for RHEL 9.4 with ONTAP
NVMe over Fabrics (NVMe-oF), including NVMe over Fibre Channel (NVMe/FC) and other transports, is supported with Red Hat Enterprise Linux (RHEL) 9.4 with Asymmetric Namespace Access (ANA). In NVMe-oF environments, ANA is the equivalent of ALUA multipathing in iSCSI and FC environments and is implemented with in-kernel NVMe multipath.
The following support is available for NVMe-oF host configuration for RHEL 9.4 with ONTAP:
Support for NVMe over TCP (NVMe/TCP) in addition to NVMe/FC. The NetApp plug-in in the native
nvme-cli
package displays ONTAP details for both NVMe/FC and NVMe/TCP namespaces. -
Use of NVMe and SCSI co-existent traffic on the same host on a given host bus adapter (HBA) without the explicit dm-multipath settings to prevent claiming NVMe namespaces.
For additional details on supported configurations, see the Interoperability Matrix Tool.
Features
RHEL 9.4 has in-kernel NVMe multipath enabled for NVMe namespaces by default; therefore, there is no need for explicit settings.
SAN booting using the NVMe/FC protocol is supported.
Known limitations
There are no known limitations.
Enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Create a SAN boot namespace and map it to the host.
Enable SAN booting in the server BIOS for the ports to which the SAN boot LUN is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Validate software versions
You can use the following procedure to validate the minimum supported RHEL 9.4 software versions.
Install RHEL 9.4 on the server. After the installation is complete, verify that you are running the specified RHEL 9.4 kernel:
# uname -r
Example output:
5.14.0-423.el9.x86_64
Install the
nvme-cli
package:# rpm -qa|grep nvme-cli
Example output:
nvme-cli-2.6-4.el9.x86_64
Install the
libnvme
package:#rpm -qa|grep libnvme
Example output
libnvme-1.6-1.el9.x86_64
On the RHEL 9.4 host, check the hostnqn string at
/etc/nvme/hostnqn
:# cat /etc/nvme/hostnqn
Example output
nqn.2014-08.org.nvmexpress:uuid: uuid:4c4c4544-0036-5610-804a-c7c04f365a32
Verify that the
hostnqn
string matches thehostnqn
string for the corresponding subsystem on the ONTAP array:::> vserver nvme subsystem host show -vserver vs_coexistence_LPE36002
Example output:
Vserver Subsystem Host NQN ----------- --------------- ---------------------------------------------------------- vs_coexistence_LPE36002 nvme nqn.2014-08.org.nvmexpress:uuid: 4c4c4544-0036-5610-804a-
If the hostnqn
strings do not match, use thevserver modify
command to update thehostnqn
string on your corresponding ONTAP array subsystem to match thehostnqn
string from/etc/nvme/hostnqn
on the host.
Configure NVMe/FC
You can configure NVMe/FC for Broadcom/Emulex or Marvell/Qlogic adapters.
Verify that you are using the supported adapter model:
# cat /sys/class/scsi_host/host*/modelname
Example output:
LPe36002-M64 LPe36002-M64
# cat /sys/class/scsi_host/host*/modeldesc
Example output:
Emulex LightPulse LPe36002-M64 2-Port 64Gb Fibre Channel Adapter Emulex LightPulse LPe36002-M64 2-Port 64Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfc
firmware and inbox driver:# cat /sys/class/scsi_host/host*/fwrev 14.2.673.40, sli-4:6:d 14.2.673.40, sli-4:6:d # cat /sys/module/lpfc/version 0:14.2.0.16
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that
lpfc_enable_fc4_type
is set to3
:# cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type 3
Verify that the initiator ports are up and running and that you can see the target LIFs:
# cat /sys/class/fc_host/host*/port_name 0x100000109b3c081f 0x100000109b3c0820
# cat /sys/class/fc_host/host*/port_state Online Online
# cat /sys/class/scsi_host/host*/nvme_info NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000109b3c081f WWNN x200000109b3c081f DID x062300 ONLINE NVME RPORT WWPN x2143d039ea165877 WWNN x2142d039ea165877 DID x061b15 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2145d039ea165877 WWNN x2142d039ea165877 DID x061115 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 000000040b Cmpl 000000040b Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000001f5c4538 Issue 000000001f58da22 OutIO fffffffffffc94ea abort 00000630 noxri 00000000 nondlp 00001071 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00000630 Err 0001bd4a NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000109b3c0820 WWNN x200000109b3c0820 DID x062c00 ONLINE NVME RPORT WWPN x2144d039ea165877 WWNN x2142d039ea165877 DID x060215 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2146d039ea165877 WWNN x2142d039ea165877 DID x061815 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 000000040b Cmpl 000000040b Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000001f5c3618 Issue 000000001f5967a4 OutIO fffffffffffd318c abort 00000629 noxri 00000000 nondlp 0000044e qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 00000629 Err 0001bd3d
The native inbox qla2xxx driver included in the RHEL 9.4 GA kernel has the latest fixes. These fixes are essential for ONTAP support.
Verify that you are running the supported adapter driver and firmware versions:
# cat /sys/class/fc_host/host*/symbolic_name
Example output
QLE2872 FW:v9.12.01 DVR:v10.02.09.100-k QLE2872 FW:v9.12.01 DVR:v10.02.09.100-k
Verify that
ql2xnvmeenable
is set. This enables the Marvell adapter to function as an NVMe/FC initiator:# cat /sys/module/qla2xxx/parameters/ql2xnvmeenable 1
Enable 1MB I/O (Optional)
ONTAP reports an MDTS (Max Data Transfer Size) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc
value of the lpfc_sg_seg_cnt
parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cnt
parameter to 256:cat /etc/modprobe.d/lpfc.conf
You should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -f
command, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cnt
is 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Configure NVMe/TCP
NVMe/TCP does not have an auto-connect functionality. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect
or connect-all
operations manually.
Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w host-traddr -a traddr
Example output:
# nvme discover -t tcp -w 192.168.167.1 -a 192.168.167.16 Discovery Log Number of Records 8, Generation counter 10 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 11 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.983de7f4b39411ee871ed039ea954d18: discovery traddr: 192.168.167.8 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 9 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.983de7f4b39411ee871ed039ea954d18: discovery traddr: 192.168.166.8 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 12 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.983de7f4b39411ee871ed039ea954d18: discovery traddr: 192.168.167.7 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 10 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.983de7f4b39411ee871ed039ea954d18: discovery traddr: 192.168.166.7 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 4====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 11 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.983de7f4b39411ee871ed039ea954d18:subsystem.nvme_tcp_1 traddr: 192.168.167.8 eflags: none sectype: none =====Discovery Log Entry 5====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 9 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.983de7f4b39411ee871ed039ea954d18:subsystem.nvme_tcp_1 traddr: 192.168.166.8 eflags: none sectype: none =====Discovery Log Entry 6====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 12 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.983de7f4b39411ee871ed039ea954d18:subsystem.nvme_tcp_1 traddr: 192.168.167.7 eflags: none sectype: none =====Discovery Log Entry 7====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 10 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.983de7f4b39411ee871ed039ea954d18:subsystem.nvme_tcp_1 traddr: 192.168.166.7 eflags: none sectype: none
Verify that the other NVMe/TCP initiator-target LIF combinations are able to successfully fetch discovery log page data:
Example output:
#nvme discover -t tcp -w 192.168.166.6 -a 192.168.166.7 #nvme discover -t tcp -w 192.168.166.6 -a 192.168.166.8 #nvme discover -t tcp -w 192.168.167.6 -a 192.168.167.7 #nvme discover -t tcp -w 192.168.167.6 -a 192.168.167.8
Run the
nvme connect-all
command across all the supported NVMe/TCP initiator-target LIFs across the nodes:nvme connect-all -t tcp -w host-traddr -a traddr
Example output:
# nvme connect-all -t tcp -w 192.168.166.6 -a 192.168.166.7 # nvme connect-all -t tcp -w 192.168.166.6 -a 192.168.166.8 # nvme connect-all -t tcp -w 192.168.167.6 -a 192.168.167.7 # nvme connect-all -t tcp -w 192.168.167.6 -a 192.168.167.8
Beginning with RHEL 9.4, the setting for the NVMe/TCP
Validate NVMe-oF
You can use the following procedure to validate NVME-oF.
Verify that the in-kernel NVMe multipath is enabled:
# cat /sys/module/nvme_core/parameters/multipath Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
# cat /sys/class/nvme-subsystem/nvme-subsys*/model NetApp ONTAP Controller NetApp ONTAP Controller
# cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
# nvme list
Example output:
Node SN Model --------------------------------------------------------- /dev/nvme4n1 81Ix2BVuekWcAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 21.47 GB / 21.47 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
NVMe/FC# nvme list-subsys /dev/nvme5n21
Example output:
nvme-subsys4 - NQN=nqn.1992-08.com.netapp:sn.efd7989cb10111ee871ed039ea954d18:subsystem.nvme hostnqn=nqn.2014-08.org.nvmexpress:uuid:d3b581b4-c975-11e6-8425-0894ef31a074 iopolicy=round-robin \ +- nvme2 fc traddr=nn-0x2013d039ea951c45:pn-0x2018d039ea951c45,host_traddr=nn-0x200000109bdacc76:pn-0x100000109bdacc76 live non-optimized +- nvme3 fc traddr=nn-0x2013d039ea951c45:pn-0x2017d039ea951c45,host_traddr=nn-0x200000109bdacc75:pn-0x100000109bdacc75 live non-optimized +- nvme5 fc traddr=nn-0x2013d039ea951c45:pn-0x2016d039ea951c45,host_traddr=nn- 0x200000109bdacc76:pn-0x100000109bdacc76 live optimized +- nvme6 fc traddr=nn-0x2013d039ea951c45:pn-0x2014d039ea951c45,host_traddr=nn- 0x200000109bdacc75:pn-0x100000109bdacc75 live optimized
NVMe/TCP# nvme list-subsys /dev/nvme1n1
Example output:
nvme-subsys1 -NQN=nqn.1992-08.com.netapp: sn.983de7f4b39411ee871ed039ea954d18:subsystem.nvme_tcp_1 hostnqn=nqn.2014-08.org.nvmexpress:uuid: 4c4c4544-0035-5910-804b-c2c04f444d33 iopolicy=round-robin \ +- nvme5 tcp traddr=192.168.166.7,trsvcid=4420,host_traddr=192.168.166.6,src_addr=192.168.166.6 live +- nvme4 tcp traddr=192.168.166.8,trsvcid=4420,host_traddr=192.168.166.6,src_addr=192.168.166.6 live +- nvme2 tcp traddr=192.168.167.7,trsvcid=4420,host_traddr=192.168.167.6,src_addr=192.168.167.6 live +- nvme1 tcp traddr=192.168.167.8,trsvcid=4420,host_traddr=192.168.167.6,src_addr=192.168.167.6 live
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Column# nvme netapp ontapdevices -o column
Example output:
Device Vserver Namespace Path ----------------------- ------------------------------ /dev/nvme0n1 vs_tcp /vol/vol1/ns1 NSID UUID Size ------------------------------------------------------------ 1 6fcb8ea0-dc1e-4933-b798-8a62a626cb7f 21.47GB
JSON# nvme netapp ontapdevices -o json
Example output
{ "ONTAPdevices" : [ { "Device" : "/dev/nvme1n1", "Vserver" : "linux_tcnvme_iscsi", "Namespace_Path" : "/vol/tcpnvme_1_0_0/tcpnvme_ns", "NSID" : 1, "UUID" : "1a42c652-1450-4a29-886a-b4ccc23e637d", "Size" : "21.47GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 5242880 }, ] }
Known issues
There are no known issues for the NVMe-oF host configuration for RHEL 9.4 with ONTAP release.
