NVMe-oF host configuration for SUSE Linux Enterprise Server 15 SP7 with ONTAP
SUSE Linux Enterprise Server hosts support the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
You can use the following support and features with the NVMe-oF host configuration for SUSE Linux Enterprise Server 15 SP7. You should also review the known limitations before starting the configuration process.
Support available:
Support for NVMe over TCP (NVMe/TCP) in addition to NVMe over Fibre Channel (NVMe/FC). The NetApp plug-in in the native
nvme-clipackage displays ONTAP details for both NVMe/FC and NVMe/TCP namespaces. -
Running both NVMe and SCSI traffic on the same host. For example, you can configure dm-multipath for SCSI mpath devices for SCSI LUNs and use NVMe multipath to configure NVMe-oF namespace devices on the host.
Support for SAN booting using the NVMe/FC protocol.
Beginning with ONTAP 9.12.1, support for secure in-band authentication is introduced for NVMe/TCP and NVMe/FC. You can use secure in-band authentication for NVMe/TCP and NVMe/FC with SUSE Linux Enterprise Server 15 SP7.
Support for persistent discovery controllers (PDCs) using a unique discovery NQN.
TLS 1.3 encryption support for NVMe/TCP.
NetApp
sanlunhost utility support isn't available for NVMe-oF on a SUSE Linux Enterprise Server15 SP7 host. Instead, you can rely on the NetApp plug-in included in the nativenvme-clipackage for all NVMe-oF transports.For additional details on supported configurations, see the Interoperability Matrix Tool.
Features available:
There are no new features available.
Known limitations
Avoid issuing the
nvme disconnect-allcommand on systems booting from SAN over NVMe-TCP or NVMe-FC namespaces because it disconnects both root and data filesystems and might lead to system instability.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Create a SAN boot namespace and map it to the host.
Enable SAN booting in the server BIOS for the ports to which the SAN boot namespace is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Step 2: Validate software versions
Use the following procedure to validate the minimum supported SUSE Linux Enterprise Server 15 SP7 software versions.
Install SUSE Linux Enterprise Server15 SP7 on the server. After the installation is complete, verify that you are running the specified SUSE Linux Enterprise Server 15 SP7 kernel:
uname -rThe following example shows a SUSE Linux Enterprise Server kernel version:
6.4.0-150700.53.3-default
Install the
nvme-clipackage:rpm -qa|grep nvme-cliThe following example shows an
nvme-clipackage version:nvme-cli-2.11+22.gd31b1a01-150700.3.3.2.x86_64
Install the
libnvmepackage:rpm -qa|grep libnvmeThe following example shows an
libnvmepackage version:libnvme1-1.11+4.ge68a91ae-150700.4.3.2.x86_64
On the host, check the hostnqn string at
/etc/nvme/hostnqn:cat /etc/nvme/hostnqnThe following example shows a
hostnqnversion:nqn.2014-08.org.nvmexpress:uuid:f6517cae-3133-11e8-bbff-7ed30aef123f
Verify that the
hostnqnstring matches thehostnqnstring for the corresponding subsystem on the ONTAP array:::> vserver nvme subsystem host show -vserver vs_coexistence_LPE36002Show example
Vserver Subsystem Priority Host NQN ------- --------- -------- ------------------------------------------------ vs_coexistence_LPE36002 nvme regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048-b9c04f425633 nvme_1 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048-b9c04f425633 nvme_2 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048-b9c04f425633 nvme_3 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048-b9c04f425633 4 entries were displayed.If the hostnqnstrings do not match, use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP array subsystem to match thehostnqnstring from/etc/nvme/hostnqnon the host.
Step 3: Configure NVMe/FC
You can configure NVMe/FC with Broadcom/Emulex FC or Marvell/Qlogic FC adapters. You also need to manually discover the NVMe/TCP subsystems and namespaces.
Configure NVMe/FC for a Broadcom/Emulex FC adapter.
Verify that you are using the supported adapter model:
Display the model names:
cat /sys/class/scsi_host/host*/modelnameYou should see the following output:
LPe36002-M64 LPe36002-M64
Display the model descriptions:
cat /sys/class/scsi_host/host*/modeldescYou should see an output similar to the following example:
Emulex LightPulse LPe36002-M64 2-Port 64Gb Fibre Channel Adapter Emulex LightPulse LPe36002-M64 2-Port 64Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfcfirmware and inbox driver:-
Display the firmware version:
cat /sys/class/scsi_host/host*/fwrevThe following example shows firmware versions:
14.4.393.25, sli-4:2:c 14.4.393.25, sli-4:2:c
Display the inbox driver version:
cat /sys/module/lpfc/versionThe following example shows a driver version:
0:14.4.0.8
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that the expected output of
lpfc_enable_fc4_typeis set to3:cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type -
Verify that you can view your initiator ports:
cat /sys/class/fc_host/host*/port_nameThe following example shows port identities:
0x10000090fae0ec88 0x10000090fae0ec89
Verify that your initiator ports are online:
cat /sys/class/fc_host/host*/port_stateYou should see the following output:
Online Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_infoShow example output
NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x10000090fae0ec88 WWNN x20000090fae0ec88 DID x0a1300 ONLINE NVME RPORT WWPN x23b1d039ea359e4a WWNN x23aed039ea359e4a DID x0a1c01 TARGET DISCSRVC ONLINE NVME RPORT WWPN x22bbd039ea359e4a WWNN x22b8d039ea359e4a DID x0a1c0b TARGET DISCSRVC ONLINE NVME RPORT WWPN x2362d039ea359e4a WWNN x234ed039ea359e4a DID x0a1c10 TARGET DISCSRVC ONLINE NVME RPORT WWPN x23afd039ea359e4a WWNN x23aed039ea359e4a DID x0a1a02 TARGET DISCSRVC ONLINE NVME RPORT WWPN x22b9d039ea359e4a WWNN x22b8d039ea359e4a DID x0a1a0b TARGET DISCSRVC ONLINE NVME RPORT WWPN x2360d039ea359e4a WWNN x234ed039ea359e4a DID x0a1a11 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000004ea0 Cmpl 0000004ea0 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 0000000000102c35 Issue 0000000000102c2d OutIO fffffffffffffff8 abort 00000175 noxri 00000000 nondlp 0000021d qdepth 00000000 wqerr 00000007 err 00000000 FCP CMPL: xb 00000175 Err 0000058b NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x10000090fae0ec89 WWNN x20000090fae0ec89 DID x0a1200 ONLINE NVME RPORT WWPN x23b2d039ea359e4a WWNN x23aed039ea359e4a DID x0a1d01 TARGET DISCSRVC ONLINE NVME RPORT WWPN x22bcd039ea359e4a WWNN x22b8d039ea359e4a DID x0a1d0b TARGET DISCSRVC ONLINE NVME RPORT WWPN x2363d039ea359e4a WWNN x234ed039ea359e4a DID x0a1d10 TARGET DISCSRVC ONLINE NVME RPORT WWPN x23b0d039ea359e4a WWNN x23aed039ea359e4a DID x0a1b02 TARGET DISCSRVC ONLINE NVME RPORT WWPN x22bad039ea359e4a WWNN x22b8d039ea359e4a DID x0a1b0b TARGET DISCSRVC ONLINE NVME RPORT WWPN x2361d039ea359e4a WWNN x234ed039ea359e4a DID x0a1b11 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000004e31 Cmpl 0000004e31 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 00000000001017f2 Issue 00000000001017ef OutIO fffffffffffffffd abort 0000018a noxri 00000000 nondlp 0000012e qdepth 00000000 wqerr 00000004 err 00000000 FCP CMPL: xb 0000018a Err 000005ca
Configure NVMe/FC for a Marvell/QLogic adapter.
Verify that you are running the supported adapter driver and firmware versions:
cat /sys/class/fc_host/host*/symbolic_nameThe follow example shows driver and firmware versions:
QLE2742 FW:v9.14.00 DVR:v10.02.09.400-k-debug QLE2742 FW:v9.14.00 DVR:v10.02.09.400-k-debug
Verify that
ql2xnvmeenableis set. This enables the Marvell adapter to function as an NVMe/FC initiator:cat /sys/module/qla2xxx/parameters/ql2xnvmeenableThe expected output is 1.
Step 4: Optionally, enable 1MB I/O
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 5: Verify NVMe boot services
With SUSE Linux Enterprise Server 15 SP7, the nvmefc-boot-connections.service and nvmf-autoconnect.service boot services included in the NVMe/FC nvme-cli package are automatically enabled to start during the system boot. After the system boot completes, verify that the boot services are enabled.
Verify that
nvmf-autoconnect.serviceis enabled:systemctl status nvmf-autoconnect.serviceShow example output
nvmf-autoconnect.service - Connect NVMe-oF subsystems automatically during boot Loaded: loaded (/usr/lib/systemd/system/nvmf-autoconnect.service; enabled; preset: enabled) Active: inactive (dead) since Fri 2025-07-04 23:56:38 IST; 4 days ago Main PID: 12208 (code=exited, status=0/SUCCESS) CPU: 62ms Jul 04 23:56:26 localhost systemd[1]: Starting Connect NVMe-oF subsystems automatically during boot... Jul 04 23:56:38 localhost systemd[1]: nvmf-autoconnect.service: Deactivated successfully. Jul 04 23:56:38 localhost systemd[1]: Finished Connect NVMe-oF subsystems automatically during boot. -
Verify that
nvmefc-boot-connections.serviceis enabled:systemctl status nvmefc-boot-connections.serviceShow example output
nvmefc-boot-connections.service - Auto-connect to subsystems on FC-NVME devices found during boot Loaded: loaded (/usr/lib/systemd/system/nvmefc-boot-connections.service; enabled; preset: enabled) Active: inactive (dead) since Mon 2025-07-07 19:52:30 IST; 1 day 4h ago Main PID: 2945 (code=exited, status=0/SUCCESS) CPU: 14ms Jul 07 19:52:30 HP-DL360-14-168 systemd[1]: Starting Auto-connect to subsystems on FC-NVME devices found during boot... Jul 07 19:52:30 HP-DL360-14-168 systemd[1]: nvmefc-boot-connections.service: Deactivated successfully. Jul 07 19:52:30 HP-DL360-14-168 systemd[1]: Finished Auto-connect to subsystems on FC-NVME devices found during boot.
Step 6: Configure NVMe/TCP
The NVMe/TCP protocol doesn't support the auto-connect operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w <host-traddr> -a <traddr>
Show example output
nvme discover -t tcp -w 192.168.111.80 -a 192.168.111.70 Discovery Log Number of Records 8, Generation counter 42 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 4 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:discovery traddr: 192.168.211.71 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 3 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:discovery traddr: 192.168.111.71 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 2 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:discovery traddr: 192.168.211.70 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 1 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:discovery traddr: 192.168.111.70 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 4====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 4 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:subsystem.sample_tcp_sub traddr: 192.168.211.71 eflags: none sectype: none =====Discovery Log Entry 5====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 3 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:subsystem.sample_tcp_sub traddr: 192.168.111.71 eflags: none sectype: none =====Discovery Log Entry 6====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 2 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:subsystem.sample_tcp_sub traddr: 192.168.211.70 eflags: none sectype: none =====Discovery Log Entry 7====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 1 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:subsystem.sample_tcp_sub traddr: 192.168.111.70 eflags: none sectype: none localhost:~ #
Verify that all other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
Show example
nvme discover -t tcp -w 192.168.111.80 -a 192.168.111.66 nvme discover -t tcp -w 192.168.111.80 -a 192.168.111.67 nvme discover -t tcp -w 192.168.211.80 -a 192.168.211.66 nvme discover -t tcp -w 192.168.211.80 -a 192.168.211.67
Run the
nvme connect-allcommand across all the supported NVMe/TCP initiator-target LIFs across the nodes:nvme connect-all -t tcp -w <host-traddr> -a <traddr>
Show example
nvme connect-all -t tcp -w 192.168.111.80 -a 192.168.111.66 nvme connect-all -t tcp -w 192.168.111.80 -a 192.168.111.67 nvme connect-all -t tcp -w 192.168.211.80 -a 192.168.211.66 nvme connect-all -t tcp -w 192.168.211.80 -a 192.168.211.67
Beginning with SUSE Linux Enterprise Server 15 SP6, the default setting for the NVMe/TCP ctrl-loss-tmo timeout is turned off. This means that there is no limit on the number of retries (indefinite retry), and you don't need to manually configure a specific ctrl-loss-tmo timeout duration when using the nvme connect or nvme connect-all commands (option -l). Additonally, the NVMe/TCP controllers don't experience timeouts in the event of a path failure and remain connected indefinitely.
Step 7: Validate NVMe-oF
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipathYou should see the following output:
Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
Display the subsystems:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelYou should see the following output:
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyYou should see the following output:
round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
nvme listShow example
Node SN Model --------------------------------------------------------- /dev/nvme4n1 81Ix2BVuekWcAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 21.47 GB / 21.47 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
NVMe/FCnvme list-subsys /dev/nvme4n5
Show example output
nvme-subsys114 - NQN=nqn.1992-08.com.netapp:sn.9e30b9760a4911f08c87d039eab67a95:subsystem.sles_161_27 hostnqn=nqn.2014-08.org.nvmexpress:uuid:f6517cae-3133-11e8-bbff-7ed30aef123f iopolicy=round-robin\ +- nvme114 fc traddr=nn-0x234ed039ea359e4a:pn-0x2360d039ea359e4a,host_traddr=nn-0x20000090fae0ec88:pn-0x10000090fae0ec88 live optimized +- nvme115 fc traddr=nn-0x234ed039ea359e4a:pn-0x2362d039ea359e4a,host_traddr=nn-0x20000090fae0ec88:pn-0x10000090fae0ec88 live non-optimized +- nvme116 fc traddr=nn-0x234ed039ea359e4a:pn-0x2361d039ea359e4a,host_traddr=nn-0x20000090fae0ec89:pn-0x10000090fae0ec89 live optimized +- nvme117 fc traddr=nn-0x234ed039ea359e4a:pn-0x2363d039ea359e4a,host_traddr=nn-0x20000090fae0ec89:pn-0x10000090fae0ec89 live non-optimizedNVMe/TCPnvme list-subsys /dev/nvme9n1
Show example output
nvme-subsys9 - NQN=nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:subsystem.with_inband_with_json hostnqn=nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0035-5910-804b-b2c04f444d33 iopolicy=round-robin \ +- nvme10 tcp traddr=192.168.111.71,trsvcid=4420,src_addr=192.168.111.80 live non-optimized +- nvme11 tcp traddr=192.168.211.70,trsvcid=4420,src_addr=192.168.211.80 live optimized +- nvme12 tcp traddr=192.168.111.70,trsvcid=4420,src_addr=192.168.111.80 live optimized +- nvme9 tcp traddr=192.168.211.71,trsvcid=4420,src_addr=192.168.211.80 live non-optimized
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
nvme netapp ontapdevices -o column
Show example
Device Vserver Namespace Path NSID UUID Size ---------------- ------------------------- -------------------------------------------------- ---- -------------------------------------- --------- /dev/nvme0n1 vs_161 /vol/fc_nvme_vol1/fc_nvme_ns1 1 32fd92c7-0797-428e-a577-fdb3f14d0dc3 5.37GB
nvme netapp ontapdevices -o json
Show example
"Device":"/dev/nvme98n2",
"Vserver":"vs_161",
"Namespace_Path":"/vol/fc_nvme_vol71/fc_nvme_ns71",
"NSID":2,
"UUID":"39d634c4-a75e-4fbd-ab00-3f9355a26e43",
"LBA_Size":4096,
"Namespace_Size":5368709120,
"UsedBytes":430649344,
Step 8: Create a persistent discovery controller
Beginning with ONTAP 9.11.1, you can create a persistent discovery controller (PDC) for a SUSE Linux Enterprise Server 15 SP7 host. A PDC is required to automatically detect an NVMe subsystem add or remove operation and changes to the discovery log page data.
Verify that the discovery log page data is available and can be retrieved through the initiator port and target LIF combination:
nvme discover -t <trtype> -w <host-traddr> -a <traddr>Show example output
Discovery Log Number of Records 8, Generation counter 18 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 4 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:discovery traddr: 192.168.111.66 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 2 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:discovery traddr: 192.168.211.66 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 3 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:discovery traddr: 192.168.111.67 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 1 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:discovery traddr: 192.168.211.67 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 4====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 4 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:subsystem.pdc traddr: 192.168.111.66 eflags: none sectype: none =====Discovery Log Entry 5====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 2 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:subsystem.pdc traddr: 192.168.211.66 eflags: none sectype: none =====Discovery Log Entry 6====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 3 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:subsystem.pdc traddr: 192.168.111.67 eflags: none sectype: none =====Discovery Log Entry 7====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 1 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:subsystem.pdc traddr: 192.168.211.67 eflags: none sectype: none
Create a PDC for the discovery subsystem:
nvme discover -t <trtype> -w <host-traddr> -a <traddr> -pYou should see the following output:
nvme discover -t tcp -w 192.168.111.80 -a 192.168.111.66 -p
From the ONTAP controller, verify that the PDC has been created:
vserver nvme show-discovery-controller -instance -vserver <vserver_name>Show example output
vserver nvme show-discovery-controller -instance -vserver vs_pdc Vserver Name: vs_pdc Controller ID: 0101h Discovery Subsystem NQN: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:discovery Logical Interface: lif2 Node: A400-12-181 Host NQN: nqn.2014-08.org.nvmexpress:uuid:9796c1ec-0d34-11eb-b6b2-3a68dd3bab57 Transport Protocol: nvme-tcp Initiator Transport Address: 192.168.111.80 Transport Service Identifier: 8009 Host Identifier: 9796c1ec0d3411ebb6b23a68dd3bab57 Admin Queue Depth: 32 Header Digest Enabled: false Data Digest Enabled: false Keep-Alive Timeout (msec): 30000
Step 9: Set up secure in-band authentication
Beginning with ONTAP 9.12.1, secure in-band authentication is supported over NVMe/TCP and NVMe/FC between the host and the ONTAP controller.
To set up secure authentication, each host or controller must be associated with a DH-HMAC-CHAP key, which is a combination of the NQN of the NVMe host or controller and an authentication secret configured by the administrator. To authenticate its peer, an NVMe host or controller must recognize the key associated with the peer.
You can set up secure in-band authentication using the CLI or a config JSON file. If you need to specify different dhchap keys for different subsystems, you must use a config JSON file.
Set up secure in-band authentication using the CLI.
Obtain the host NQN:
cat /etc/nvme/hostnqn -
Generate the dhchap key for the host.
The following output describes the
gen-dhchap-keycommand paramters:nvme gen-dhchap-key -s optional_secret -l key_length {32|48|64} -m HMAC_function {0|1|2|3} -n host_nqn • -s secret key in hexadecimal characters to be used to initialize the host key • -l length of the resulting key in bytes • -m HMAC function to use for key transformation 0 = none, 1- SHA-256, 2 = SHA-384, 3=SHA-512 • -n host NQN to use for key transformationIn the following example, a random dhchap key with HMAC set to 3 (SHA-512) is generated.
nvme gen-dhchap-key -m 3 -n nqn.2014-08.org.nvmexpress:uuid:e6dade64-216d-11ec-b7bb-7ed30a5482c3 DHHC-1:03:1CFivw9ccz58gAcOUJrM7Vs98hd2ZHSr+iw+Amg6xZPl5D2Yk+HDTZiUAg1iGgxTYqnxukqvYedA55Bw3wtz6sJNpR4=:
On the ONTAP controller, add the host and specify both dhchap keys:
vserver nvme subsystem host add -vserver <svm_name> -subsystem <subsystem> -host-nqn <host_nqn> -dhchap-host-secret <authentication_host_secret> -dhchap-controller-secret <authentication_controller_secret> -dhchap-hash-function {sha-256|sha-512} -dhchap-group {none|2048-bit|3072-bit|4096-bit|6144-bit|8192-bit} -
A host supports two types of authentication methods, unidirectional and bidirectional. On the host, connect to the ONTAP controller and specify dhchap keys based on the chosen authentication method:
nvme connect -t tcp -w <host-traddr> -a <tr-addr> -n <host_nqn> -S <authentication_host_secret> -C <authentication_controller_secret>
Validate the
nvme connect authenticationcommand by verifying the host and controller dhchap keys:-
Verify the host dhchap keys:
cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_secretShow example output for a unidirectional configuration
# cat /sys/class/nvme-subsystem/nvme-subsys1/nvme*/dhchap_secret DHHC-1:01:iM63E6cX7G5SOKKOju8gmzM53qywsy+C/YwtzxhIt9ZRz+ky: DHHC-1:01:iM63E6cX7G5SOKKOju8gmzM53qywsy+C/YwtzxhIt9ZRz+ky: DHHC-1:01:iM63E6cX7G5SOKKOju8gmzM53qywsy+C/YwtzxhIt9ZRz+ky: DHHC-1:01:iM63E6cX7G5SOKKOju8gmzM53qywsy+C/YwtzxhIt9ZRz+ky:
Verify the controller dhchap keys:
cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_ctrl_secretShow example output for a bidirectional configuration
# cat /sys/class/nvme-subsystem/nvme-subsys6/nvme*/dhchap_ctrl_secret DHHC-1:03:1CFivw9ccz58gAcOUJrM7Vs98hd2ZHSr+iw+Amg6xZPl5D2Yk+HDTZiUAg1iGgxTYqnxukqvYedA55Bw3wtz6sJNpR4=: DHHC-1:03:1CFivw9ccz58gAcOUJrM7Vs98hd2ZHSr+iw+Amg6xZPl5D2Yk+HDTZiUAg1iGgxTYqnxukqvYedA55Bw3wtz6sJNpR4=: DHHC-1:03:1CFivw9ccz58gAcOUJrM7Vs98hd2ZHSr+iw+Amg6xZPl5D2Yk+HDTZiUAg1iGgxTYqnxukqvYedA55Bw3wtz6sJNpR4=: DHHC-1:03:1CFivw9ccz58gAcOUJrM7Vs98hd2ZHSr+iw+Amg6xZPl5D2Yk+HDTZiUAg1iGgxTYqnxukqvYedA55Bw3wtz6sJNpR4=:
When multiple NVMe subsystems are available on the ONTAP controller configuration, you can use the /etc/nvme/config.json file with the nvme connect-all command.
To generate the JSON file, you can use the -o option. See the NVMe connect-all manual pages for more syntax options.
Configure the JSON file:
Show example output
# cat /etc/nvme/config.json [ { "hostnqn":"nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0035-5910-804b-b2c04f444d33", "hostid":"4c4c4544-0035-5910-804b-b2c04f444d33", "dhchap_key":"DHHC-1:01:i4i789R11sMuHLCY27RVI8XloC\/GzjRwyhxip5hmIELsHrBq:", "subsystems":[ { "nqn":"nqn.1992-08.com.netapp:sn.f8e2af201b7211f0ac2bd039eab67a95:subsystem.sample_tcp_sub", "ports":[ { "transport":"tcp", "traddr":"192.168.111.70", "host_traddr":"192.168.111.80", "trsvcid":"4420" "dhchap_ctrl_key":"DHHC-1:03:jqgYcJSKp73+XqAf2X6twr9ngBpr2n0MGWbmZIZq4PieKZCoilKGef8lAvhYS0PNK7T+04YD5CRPjh+m3qjJU++yR8s=:" }, { "transport":"tcp", "traddr":"192.168.111.71", "host_traddr":"192.168.111.80", "trsvcid":"4420", "dhchap_ctrl_key":"DHHC-1:03:jqgYcJSKp73+XqAf2X6twr9ngBpr2n0MGWbmZIZq4PieKZCoilKGef8lAvhYS0PNK7T+04YD5CRPjh+m3qjJU++yR8s=:" }, { "transport":"tcp", "traddr":"192.168.211.70", "host_traddr":"192.168.211.80", "trsvcid":"4420", "dhchap_ctrl_key":"DHHC-1:03:jqgYcJSKp73+XqAf2X6twr9ngBpr2n0MGWbmZIZq4PieKZCoilKGef8lAvhYS0PNK7T+04YD5CRPjh+m3qjJU++yR8s=:" }, { "transport":"tcp", "traddr":"192.168.211.71", "host_traddr":"192.168.211.80", "trsvcid":"4420", "dhchap_ctrl_key":"DHHC-1:03:jqgYcJSKp73+XqAf2X6twr9ngBpr2n0MGWbmZIZq4PieKZCoilKGef8lAvhYS0PNK7T+04YD5CRPjh+m3qjJU++yR8s=:" } ] } ] } ]In the preceding example, dhchap_keycorresponds todhchap_secretanddhchap_ctrl_keycorresponds todhchap_ctrl_secret. -
Connect to the ONTAP controller using the config JSON file:
nvme connect-all -J /etc/nvme/config.jsonShow example output
traddr=192.168.211.70 is already connected traddr=192.168.111.71 is already connected traddr=192.168.211.71 is already connected traddr=192.168.111.70 is already connected traddr=192.168.211.70 is already connected traddr=192.168.111.70 is already connected traddr=192.168.211.71 is already connected traddr=192.168.111.71 is already connected traddr=192.168.211.70 is already connected traddr=192.168.111.71 is already connected traddr=192.168.211.71 is already connected traddr=192.168.111.70 is already connected
Verify that the dhchap secrets have been enabled for the respective controllers for each subsystem:
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_secretYou should see the following output:
DHHC-1:01:i4i789R11sMuHLCY27RVI8XloC/GzjRwyhxip5hmIELsHrBq:
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_ctrl_secretYou should see the following output:
Step 10: Configure Transport Layer Security
Transport Layer Security (TLS) provides secure end-to-end encryption for NVMe connections between NVMe-oF hosts and an ONTAP array. Beginning with ONTAP 9.16.1, you can configure TLS 1.3 using the CLI and a configured pre-shared key (PSK).
You perform the steps in this procedure on the SUSE Linux Enterprise Server host, except where it specifies that you perform a step on the ONTAP controller.
Check that you have the following
ktls-utils,openssl, andlibopensslpackages installed on the host:-
Verify the
ktls-utils:rpm -qa | grep ktlsYou should see the following output displayed:
ktls-utils-0.10+33.g311d943-150700.1.5.x86_64
Verify the SSL packages:
rpm -qa | grep sslShow example output
libopenssl3-3.2.3-150700.3.20.x86_64 openssl-3-3.2.3-150700.3.20.x86_64 libopenssl1_1-1.1.1w-150700.9.37.x86_64
Verify that you have the correct setup for
/etc/tlshd.conf:cat /etc/tlshd.confShow example output
[debug] loglevel=0 tls=0 nl=0 [authenticate] keyrings=.nvme [authenticate.client] #x509.truststore= <pathname> #x509.certificate= <pathname> #x509.private_key= <pathname> [authenticate.server] #x509.truststore= <pathname> #x509.certificate= <pathname> #x509.private_key= <pathname>
Enable
tlshdto start at system boot:systemctl enable tlshd -
Verify that the
tlshddaemon is running:systemctl status tlshdShow example output
tlshd.service - Handshake service for kernel TLS consumers Loaded: loaded (/usr/lib/systemd/system/tlshd.service; enabled; preset: disabled) Active: active (running) since Wed 2024-08-21 15:46:53 IST; 4h 57min ago Docs: man:tlshd(8) Main PID: 961 (tlshd) Tasks: 1 CPU: 46ms CGroup: /system.slice/tlshd.service └─961 /usr/sbin/tlshd Aug 21 15:46:54 RX2530-M4-17-153 tlshd[961]: Built from ktls-utils 0.11-dev on Mar 21 2024 12:00:00 -
Generate the TLS PSK by using the
nvme gen-tls-key:-
Verify the host:
cat /etc/nvme/hostnqnYou should see the following output:
Verify the key:
nvme gen-tls-key --hmac=1 --identity=1 --subsysnqn= nqn.1992-08.com.netapp:sn.a2d41235b78211efb57dd039eab67a95:subsystem.nvme1You should see the following output:
NVMeTLSkey-1:01:C50EsaGtuOp8n5fGE9EuWjbBCtshmfoHx4XTqTJUmydf0gIj:
On the ONTAP controller, add the TLS PSK to the ONTAP subsystem:
Show example output
nvme subsystem host add -vserver vs_iscsi_tcp -subsystem nvme1 -host-nqn nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0035-5910-804b-b2c04f444d33 -tls-configured-psk NVMeTLSkey-1:01:C50EsaGtuOp8n5fGE9EuWjbBCtshmfoHx4XTqTJUmydf0gIj:
Insert the TLS PSK into the host kernel keyring:
nvme check-tls-key --identity=1 --subsysnqn=nqn.1992-08.com.netapp:sn.a2d41235b78211efb57dd039eab67a95:subsystem.nvme1 --keydata=NVMeTLSkey-1:01:C50EsaGtuOp8n5fGE9EuWjbBCtshmfoHx4XTqTJUmydf0gIj: --insertYou should see the following TLS key:
Inserted TLS key 22152a7e
The PSK shows as NVMe1R01because it usesidentity v1from the TLS handshake algorithm. Identity v1 is the only version that ONTAP supports. -
Verify that the TLS PSK is inserted correctly:
cat /proc/keys | grep NVMeShow example output
069f56bb I--Q--- 5 perm 3b010000 0 0 psk NVMe1R01 nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0035-5910-804b-b2c04f444d33 nqn.1992-08.com.netapp:sn.a2d41235b78211efb57dd039eab67a95:subsystem.nvme1 oYVLelmiOwnvDjXKBmrnIgGVpFIBDJtc4hmQXE/36Sw=: 32
Connect to the ONTAP subsystem using the inserted TLS PSK:
Verify the TLS PSK:
nvme connect -t tcp -w 192.168.111.80 -a 192.168.111.66 -n nqn.1992-08.com.netapp:sn.a2d41235b78211efb57dd039eab67a95:subsystem.nvme1 --tls_key=0x069f56bb –tlsYou should see the following output:
connecting to device: nvme0
Verify the list-subsys:
nvme list-subsysShow example output
nvme-subsys0 - NQN=nqn.1992-08.com.netapp:sn.a2d41235b78211efb57dd039eab67a95:subsystem.nvme1 hostnqn=nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0035-5910-804b-b2c04f444d33 \ +- nvme0 tcp traddr=192.168.111.66,trsvcid=4420,host_traddr=192.168.111.80,src_addr=192.168.111.80 live
Add the target, and verify the TLS connection to the specified ONTAP subsystem:
nvme subsystem controller show -vserver sles15_tls -subsystem sles15 -instanceShow example output
(vserver nvme subsystem controller show) Vserver Name: vs_iscsi_tcp Subsystem: nvme1 Controller ID: 0040h Logical Interface: tcpnvme_lif1_1 Node: A400-12-181 Host NQN: nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0035-5910-804b-b2c04f444d33 Transport Protocol: nvme-tcp Initiator Transport Address: 192.168.111.80 Host Identifier: 4c4c454400355910804bb2c04f444d33 Number of I/O Queues: 2 I/O Queue Depths: 128, 128 Admin Queue Depth: 32 Max I/O Size in Bytes: 1048576 Keep-Alive Timeout (msec): 5000 Subsystem UUID: 8bbfb403-1602-11f0-ac2b-d039eab67a95 Header Digest Enabled: false Data Digest Enabled: false Authentication Hash Function: sha-256 Authentication Diffie-Hellman Group: 3072-bit Authentication Mode: unidirectional Transport Service Identifier: 4420 TLS Key Type: configured TLS PSK Identity: NVMe1R01 nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0035-5910-804b-b2c04f444d33 nqn.1992-08.com.netapp:sn.a2d41235b78211efb57dd039eab67a95:subsystem.nvme1 oYVLelmiOwnvDjXKBmrnIgGVpFIBDJtc4hmQXE/36Sw= TLS Cipher: TLS-AES-128-GCM-SHA256
Step 11: Review the known issues
There are no known issues.
