Modify a host management server
You can use the host modify command to modify a host management server with this instance of ONTAP Select Deploy.
Syntax
host modify [-help] [-foreground] -name name -mgmt-server management_server [-username username]
Required parameters
Parameter |
Description |
The IP address or FQDN of the host you want to modify. |
The IP address or FQDN of the host management server to be set to the host. Specify "-" (hyphen) to unset the management server from the host. The credentials for this management server must be added prior to registering this host using the |
Optional parameters
Parameter |
Description |
Displays the help message. |
This parameter controls the behavior of long-running commands. If set, the command will run in the foreground and event messages related to the operation will be displayed as they occur. |
The username that has access to this host. This is required only if the host is not managed by a management server (that is, an ESX host managed by a vCenter). |
