Security
There are several related tasks you can perform as part of securing an ONTAP Select deployment.
Change the Deploy administrator password
You can change the password for the Deploy virtual machine administrator account as needed using the command line interface.
Steps
Sign in to the Deploy utility CLI using the administrator account.
Change the password:
password modify -
Respond to all prompts as appropriate for your environment.
