The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Workflow when purchasing a license
Creating your file...
Your file is ready
The following workflow illustrates the process of purchasing and applying a license for your ONTAP Select deployment. When purchasing a license, you must select the licensing model and storage capacity.
The exact process varies based on whether you are using a capacity tier or capacity pool license:
- Nine-digit license serial number
Serial number applies to either a node (capacity tiers) or a storage pool (capacity pools)
- License Lock ID
You must have the License Lock ID for your Deploy instance when using a capacity pool license
- Licensing web site
You obtain a capacity tier and capacity pool license at different web sites
