ONTAP Select
Required information for Deploy utility installation
Before installing the Deploy administration utility in a hypervisor environment, review the required configuration information and optional network configuration information to prepare for successful deployment.
Required configuration information
As part of your deployment planning, you should determine the required configuration information before installing the ONTAP Select Deploy administration utility.
Required information Description
Name of the Deploy virtual machine
Identifier to use for the virtual machine.
Name of the hypervisor host
Identifier for the VMware ESXi or KVM hypervisor host where the Deploy utility is installed.
Name of the data store
Identifier for the hypervisor data store holding the virtual machine files (approximately 40GB is required).
Network for the virtual machine
Identifier for the Network where the Deploy virtual machine is connected.
Optional network configuration information
The Deploy virtual machine is configured using DHCP by default. However, if needed, you can manually configure the network interface for the virtual machine.
Network information Description
Host name
Identifier of the host machine.
Host IP address
Static IPv4 address of the host machine.
Subnet mask
Subnetwork mask, based on the network the virtual machine is a part of.
Gateway
Default gateway or router.
Primary DNS server
Primary Domain Name Server.
Secondary DNS server
Secondary Domain Name Server.
Search domains
List of the search domains to use.
