Required information for ONTAP Select Deploy utility installation
Before installing the Deploy administration utility in a hypervisor environment, review the required configuration information and optional network configuration information to prepare for successful deployment.
Required configuration information
As part of your deployment planning, you should determine the required configuration information before installing the ONTAP Select Deploy administration utility.
| Required information | Description |
Name of the Deploy virtual machine (VM) |
Identifier to use for the VM. |
Name of the hypervisor host |
Identifier for the VMware ESXi, Hyper-V, or KVM hypervisor host where the Deploy utility is installed. |
Name of the storage location |
Identifier for the data store (ESXi) or storage pool (Hyper-V or KVM) holding the VM files (approximately 40GB is required). |
Network for the VM |
Identifier for the Network where the Deploy VM is connected. |
Optional network configuration information
The Deploy VM is configured using DHCP by default. However, if needed, you can manually configure the network interface for the VM.
| Network information | Description |
Host name |
Identifier of the host machine. |
Host IP address |
Static IPv4 address of the host machine. |
Subnet mask |
Subnetwork mask, based on the network the VM is a part of. |
Gateway |
Default gateway or router. |
Primary DNS server |
Primary Domain Name Server. |
Secondary DNS server |
Secondary Domain Name Server. |
Search domains |
List of the search domains to use. |
