Expand or contract an ONTAP Select cluster on ESXi or KVM hosts
Increase or decrease the cluster size of an existing ONTAP Select cluster for ESXi and KVM hypervisor hosts. For both host types, you can increase and decrease the cluster size in increments between four and twelve nodes.
The following cluster expansions and contractions aren't supported for ESXi and KVM hosts:
Expansions from one or two-node clusters to six, eight, ten, or twelve-node clusters.
Contractions from six, eight, ten, or twelve-node clusters to one or two-node clusters.
To change the number of nodes in a cluster to a size that isn't supported by cluster expansion or contraction, you need to perform the following tasks:
You initiate the cluster expansion and contraction procedures from ONTAP Select Deploy using the CLI, API, or web interface.
Hardware and storage considerations
The cluster expansion and contraction feature is supported on the following ESXi and KVM hypervisor hosts.
Beginning with ONTAP Select 9.15.1, cluster expansion and contraction is supported on ESXi hypervisor hosts.
Cluster expansion and contraction is supported for the following ESXi hypervisor versions:
ESXi 9.1
ESXi 9.0
ESXi 8.0 U3
ESXi 8.0 U2
ESXi 8.0 U1
ESXi 8.0 GA
Beginning with ONTAP Select 9.17.1, cluster expansion and contraction is supported on KVM hypervisor hosts.
Cluster expansion and contraction is supported for the following KVM hypervisor versions:
Red Hat Enterprise Linux (RHEL) 64-bit 10.1, 10.0, 9.7, 9.6, 9.5, 9.4, 9.3, 9.2, 9.1, 9.0, 8.8, 8.7, and 8.6
Rocky Linux 10.1, 10.0, 9.7, 9.6, 9.5, 9.4, 9.3, 9.2, 9.1, 9.0, 8.9, 8.8, 8.7, and 8.6
Expand the cluster
Use the cluster expansion feature to increase the size of an existing ONTAP Select cluster.
You can increase the size of an existing cluster on an ESXi or KVM host in the following increments:
From four nodes to six, eight, ten, or twelve nodes
From six nodes to eight, ten, or twelve nodes
From eight nodes to ten or twelve nodes
From ten to twelve nodes
In preparation for cluster expansion, new ESXi and KVM hosts are added to the inventory and the details of the new nodes are assigned. Before starting the cluster expansion process, a network precheck verifies the selected internal network.
Sign in to the Deploy utility web user interface using the administrator account.
Select the Cluster tab at the top of the page and select the desired cluster from the list.
On the cluster details page, select the gear icon at the right of the page and select Expand Cluster.
Navigate to the HA Pair 4 section.
Choose the following high availability (HA) pair configuration details for the fourth HA pair:
Instance type
Node names
Associated hypervisor hosts
Node IP addresses
Licenses
Networking configuration
Storage configuration (RAID type and storage pools)
Select Save HA Pair to save the configuration details.
Provide the ONTAP credentials, and select Expand Cluster.
Select Next and run the network pre-check by selecting Run.
The network pre-check validates that the internal network selected for the ONTAP cluster traffic is functioning correctly.
Select Expand Cluster to begin the cluster expansion process, and then select OK in the dialog box.
It can take up to 45 minutes for the cluster to be expanded.
Monitor the multi-step cluster expansion process to confirm that the cluster expanded successfully.
Refer to the Events tab for periodic updates on the operation's progress. The page is automatically refreshed at regular intervals.
After expanding the cluster, you should back up the ONTAP Select Deploy configuration data.
Contract the cluster
Use the cluster contraction feature to decrease the size of an existing ONTAP Select cluster.
You can decrease the size of an existing cluster on an ESXi or KVM host in the following increments:
From twelve nodes to ten, eight, six, or four nodes
From ten nodes to eight, six, or four nodes
From eight to six or four nodes
From six to four nodes
The desired HA pair of nodes in the cluster are selected to prepare for cluster contraction during the procedure.
On the cluster details page, select the gear icon at the right of the page, then select Contract Cluster.
Select the HA Pair configuration details for any HA Pair you want to remove and provide the ONTAP credentials, then select Contract Cluster.
It can take up to 30 minutes for the cluster to be contracted.
Monitor the multi-step cluster contraction process to confirm that the cluster contracted successfully.
