Platform license offerings for ONTAP Select
You can purchase an ONTAP Select Capacity Tier or Capacity Pool license in the standard, premium, or premium XL level. These license offerings determine the capabilities of the hosts where you deploy ONTAP Select.
What a platform license offering provides
A specific license offering determines the capabilities of the hypervisor host in two areas:
Instance type (CPU, memory)
Additional features
The license offerings are arranged in an ascending order of capabilities from standard to premium XL. In general, the license option you choose grants you the capabilities of that level and all lower levels. For example, the premium level provides the capabilities of both premium and standard.
The following table compares the capabilities for the standard, premium, and premium XL license offerings.
| License supports … | Standard | Premium | Premium XL | |
Instance type |
Small only |
Small or medium |
Small, medium, or large |
Hard disk drives (HDD) in a … |
Hardware RAID configuration |
Yes |
Yes |
Yes |
vNAS configuration |
Yes |
Yes |
Yes |
Solid state drives (SSDs) in a … |
No |
Yes |
Yes |
Software RAID configuration |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
NVMe drives in a … |
No |
No |
Yes |
No |
No |
Yes |
Yes |
Yes |
Yes |
MetroCluster SDS |
No |
Yes |
Yes |
Microsoft Hyper-V supports small, medium, and large instance types. Kernel-Based Virtual Machines (KVM) do not support the large instance type. |
Compare hardware support for platform license offerings
The standard, premium, and premium XL license offerings support a wide range of hardware and software. For current information on hardware and software versions, refer to the Interoperability Matrix Tool.
Core item type |
Description |
Host protocols |
NFS, SMB/CIFS, iSCSI, and NVMe over TCP |
Deployment options |
Single node |
Supported capacity (per node) |
Up to 400TB raw data (ESXi, Hyper-V, and KVM) |
Hardware type |
Description |
Instance size |
Small |
Medium |
Large |
CPU family |
Intel Xeon E5-26xx v3 (Haswell) or later AMD EPYC Embedded 9004 or later and 8004 |
ONTAP Select CPU / memory |
4 virtual CPUs (vCPUs) / 16GB of RAM |
8 vCPUs / 64GB of RAM |
16 vCPUs / 128GB of RAM |
Host CPU / memory minimum requirements 1 |
6 cores / 24GB of RAM |
10 cores / 72GB of RAM |
18 cores / 136GB of RAM |
Network (per node) |
Minimum of two 1GbE ports for a single node cluster |
1 Assumes two cores and 8GB of RAM for the hypervisor.
The following table provides the minimum license type required for the specified storage.
Storage type |
Description |
License type |
Standard |
Premium |
Premium XL |
Instance size |
Small |
Small and medium |
Small, medium, and large |
Local DAS with hardware RAID controller |
8 – 60 drives |
8 – 60 drives |
8 – 60 drives |
HDD (SAS, NL-SAS, SATA) |
Not applicable |
4 – 60 drives |
4 – 60 drives |
SSD (SAS) |
Not applicable |
4 – 60 drives |
4 – 60 drives |
NVMe |
Not applicable |
Not applicable |
4 – 14 drives |
Local DAS with software RAID |
Not applicable |
Applicable |
4 – 14 drives (NVMe only) |
External arrays 1 |
Datastores hosted on external arrays are connected through FC, FCoE, and iSCSI for ESXi, Hyper-V, and KVM, and NFS for ESXi. NFS isn't supported for KVM and Hyper-V. These datastores provide high availability and resilience. |
1 External array protocol support reflects networked storage connectivity.
Software type |
Description |
Hypervisor support (VMware) |
VMware vSphere 9.1, 9.0 |
Hypervisor support (Hyper-V) |
Windows Server 2025 and 2022 |
Hypervisor support (KVM) |
Red Hat Enterprise Linux 64-bit (KVM) 10.1, 10.0, 9.7, 9.6, 9.5, 9.4, 9.3, 9.2, 9.1, 9.0, 8.8, 8.7, and 8.6 Rocky Linux (KVM) 10.1, 10.0, 9.7, 9.6, 9.5, 9.4, 9.3, 9.2, 9.1, 9.0, 8.9, 8.8, 8.7, and 8.6 |
Management software |
NetApp Active IQ Unified Manager management suite |
Learn about purchasing an ONTAP Select license
