ONTAP Select support for ONTAP features
ONTAP Select supports most ONTAP features. Many of the ONTAP features are licensed automatically for each node when you deploy a cluster. However some features require a separate license.
ONTAP features that have hardware-specific dependencies are generally not supported with ONTAP Select. |
ONTAP features licensed by default
The following ONTAP features are supported with ONTAP Select and licensed by default.
| Feature | Learn about | Notes |
Autonomous Ransomware Protection (ARP) |
ONTAP Select only supports ARP manual updates. |
CIFS |
Deduplication and compression |
External key management using the Key Management Interoperability Protocol (KMIP) |
FlexCache |
ONTAP Select supports FlexCache cache volumes with write-back. |
FlexClone |
iSCSI |
NDMP |
NetApp Volume Encryption |
ONTAP Select supports NetApp Volume Encryption in non-restricted countries only. |
NFS |
NFS over TLS |
ONTAP Select supports NFS over TLS using the CLI. System Manager is not supported. |
NVMe over TCP |
ONTAP multitenancy capability |
ONTAP S3 |
S3 SnapMirror |
SnapLock Select |
SnapLock Select is the implementation of ONTAP SnapLock designed for ONTAP Select and includes SnapLock Enterprise. It does not include SnapLock Compliance. |
SnapMirror |
ONTAP Select does not support consistency groups in Asynchronous SnapMirror. |
SnapRestore |
SnapMirror DR, archive (previously known as SnapVault) |
Storage VM disaster recovery (SVM DR) |
ONTAP Select supports SVM DR as both a source and destination with a maximum of 16 relationships. SVM DR support is limited to the use of the source ONTAP version to versions +2. For example, the ONTAP Select 9.16.1 source can connect to destination ONTAP versions 9.16.1, 9.17.1, or 9.18.1. |
ONTAP features that are separately licensed
You need to acquire a separate license for the following ONTAP features that are supported by ONTAP Select but are not licensed by default.
| Feature | Learn about | Note |
FabricPool |
You do not need a FabricPool license when utilizing StorageGRID. |
MetroCluster SDS |
This is an ONTAP Select premium license offering. |
SnapMirror cloud |
You need to open a non-technical support case to obtain a SnapMirror cloud license. |
