ONTAP Select single and multiple node network configurations
ONTAP Select supports both single-node and multi-node network configurations.
Single node network configuration
Single-node ONTAP Select configurations do not require the ONTAP internal network, because there is no cluster, HA, or mirror traffic.
Unlike the multi-node version of the ONTAP Select product, each ONTAP Select VM contains three virtual network adapters, presented to ONTAP network ports e0a, e0b, and e0c.
These ports are used to provide the following services: management, data, and intercluster LIFs.
The following figure shows the relationship between these ports and the underlying physical adapters. The figure depicts one ONTAP Select cluster node on the ESXi hypervisor.
Network configuration of single-node ONTAP Select cluster
Even though two adapters are sufficient for a single-node cluster, NIC teaming is still required. |
You can deploy ONTAP Select as a single-node cluster. The hypervisor host includes a virtual switch that provides access to the external network.
LIF assignment
As explained in the multi-node LIF assignment section of this document, ONTAP uses IPspaces to keep cluster network traffic separate from data and management traffic. The single-node variant of this platform does not contain a cluster network. Therefore, there are no ports present in the cluster IPspace.
Cluster and node management LIFs are automatically created during ONTAP Select cluster setup. You can create the remaining LIFs post deployment. |
Management and data LIFs (e0a, e0b, and e0c)
ONTAP ports e0a, e0b, and e0c are delegated as candidate ports for LIFs that carry the following types of traffic:
SAN/NAS protocol traffic (CIFS, NFS, and iSCSI)
Cluster, node, and SVM management traffic
Intercluster traffic (SnapMirror and SnapVault)
Multi-node network configuration
The multi-node ONTAP Select network configuration consists of two networks.
These are an internal network, responsible for providing cluster and internal replication services, and an external network, responsible for providing data access and management services. End-to-end isolation of traffic that flows within these two networks is extremely important for building an environment that is suitable for cluster resiliency.
These networks are represented in the following figure, which shows a four-node ONTAP Select cluster running on a VMware vSphere platform. Six, eight, ten, and twelve-node clusters have a similar network layout.
Each ONTAP Select instance resides on a separate physical server. Internal and external traffic is isolated using separate network port groups, which are assigned to each virtual network interface and allow the cluster nodes to share the same physical switch infrastructure. |
Overview of an ONTAP Select multi-node cluster network configuration
Each ONTAP Select VM contains seven virtual network adapters presented to ONTAP as a set of seven network ports, e0a through e0g. Although ONTAP treats these adapters as physical NICs, they are in fact virtual and map to a set of physical interfaces through a virtualized network layer. As a result, each hosting server does not require six physical network ports.
Adding virtual network adapters to the ONTAP Select VM is not supported. |
These ports are preconfigured to provide the following services:
e0a, e0b, and e0g. Management and data LIFs
e0c, e0d. Cluster network LIFs
e0e. RSM
e0f. HA interconnect
Ports e0a, e0b, and e0g reside on the external network. Although ports e0c through e0f perform several different functions, collectively they compose the internal Select network. When making network design decisions, you should place these ports on a single layer-2 network. There is no need to separate these virtual adapters across different networks.
The relationship between these ports and the underlying physical adapters is illustrated in the following figure, which depicts one ONTAP Select cluster node on the ESXi hypervisor.
Network configuration of a single node that is part of a multi-node ONTAP Select cluster
Segregating internal and external traffic across different physical NICs prevents insufficient access to network resources, introducing latencies into the system. Additionally, aggregation through NIC teaming allows the ONTAP Select cluster node to continue accessing the network if a single network adapter fails.
Both the external network and internal network port groups contain all four NIC adapters in a symmetrical manner. The active ports in the external network port group are the standby ports in the internal network. Conversely, the active ports in the internal network port group are the standby ports in the external network port group. |
LIF assignment
With the introduction of IPspaces, ONTAP port roles have been deprecated. Like FAS arrays, ONTAP Select clusters contain both a default IPspace and a cluster IPspace. By placing network ports e0a, e0b, and e0g into the default IPspace and ports e0c and e0d into the cluster IPspace, those ports have essentially been walled off from hosting LIFs that do not belong. The remaining ports within the ONTAP Select cluster are consumed through the automatic assignment of interfaces providing internal services. They are not exposed through the ONTAP shell, as is the case with the RSM and HA interconnect interfaces.
Not all LIFs are visible through the ONTAP command shell. The HA interconnect and RSM interfaces are hidden from ONTAP and are used internally to provide their respective services. |
The network ports and LIFs are explained in detail in the following sections.
Management and data LIFs (e0a, e0b, and e0g)
ONTAP ports e0a, e0b, and e0g are delegated as candidate ports for LIFs that carry the following types of traffic:
Cluster network LIFs (e0c, e0d)
ONTAP ports e0c and e0d are delegated as home ports for cluster interfaces. Within each ONTAP Select cluster node, two cluster interfaces are automatically generated during ONTAP setup using link local IP addresses (169.254.x.x).
You cannot assign a static IP address to these interfaces, and you should not create additional cluster interfaces. |
Cluster network traffic must flow through a low-latency, non-routed layer-2 network. Due to cluster throughput and latency requirements, you should physically locate the ONTAP Select cluster within proximity (for example, multipack, single data center). Building four, six, eight, ten, or twelve-node stretch cluster configurations by separating HA nodes across a WAN or significant geographical distances is not supported. A stretched two-node configuration with a mediator is supported.
For details, refer to the section Two-node stretched HA (MetroCluster SDS) best practices.
To make sure of maximum throughput for cluster network traffic, this network port is configured to use jumbo frames with a Maximum Transmission Unit (MTU) of 7500 to 9000 bytes. For correct cluster operation, verify that jumbo frames are enabled on all upstream virtual and physical switches providing internal network services to ONTAP Select cluster nodes. |
RAID SyncMirror traffic (e0e)
Synchronous replication of blocks across HA partner nodes occurs using an internal network interface residing on network port e0e. This functionality occurs automatically, using network interfaces configured by ONTAP during cluster setup, and requires no configuration by the administrator.
Port e0e is reserved by ONTAP for internal replication traffic. Therefore, neither the port nor the hosted LIF is visible in the ONTAP CLI or in System Manager. This interface is configured to use an automatically generated link local IP address, and you cannot assign an alternate IP address. This network port requires the use of jumbo frames (7500 to 9000 MTU). |
HA interconnect (e0f)
NetApp FAS arrays use specialized hardware to pass information between HA pairs in an ONTAP cluster. Software-defined environments, however, do not tend to have this type of equipment available (such as InfiniBand or iWARP devices), so an alternate solution is needed. Although several possibilities were considered, ONTAP requirements placed on the interconnect transport required that this functionality be emulated in software. As a result, within an ONTAP Select cluster, the functionality of the HA interconnect (traditionally provided by hardware) has been designed into the OS, using Ethernet as a transport mechanism.
Each ONTAP Select node is configured with an HA interconnect port, e0f. This port hosts the HA interconnect network interface, which is responsible for two primary functions:
Mirroring the contents of NVRAM between HA pairs
Sending/receiving HA status information and network heartbeat messages between HA pairs
HA interconnect traffic flows through this network port using a single network interface by layering remote direct memory access (RDMA) frames within Ethernet packets.
Like the RSM port (e0e), neither the physical port nor the hosted network interface is visible to users from either the ONTAP CLI or from System Manager. As a result, you cannot modify the IP address of this interface, and you cannot change the state of the port. This network port requires the use of jumbo frames (7500 to 9000 MTU). |
