ONTAP Select
Administer the ONTAP Select Deploy mediator services
Each ONTAP Select two-node cluster is monitored by the mediator service, which assists in managing the HA capability shared by the nodes.
View the status of the mediator service
You can view the status of the mediator service with respect to each of the two-node clusters defined to the ONTAP Select Deploy utility.
About this task
You can view the configuration of each mediator, including the current status, the two ONTAP Select nodes, and the iSCSI target where the HA control information is stored. Hover over the objects on the page to display detailed information.
Steps
  1. Sign in to the Deploy utility web user interface using the administrator account.
  2. Click the Administration tab at the top of the page and click Mediators.
  3. Optionally click Filter to customize your view of the two-node clusters monitored by the mediator service.
