ONTAP Select
ONTAP Select 9.6 performance: Premium HA direct-attached SSD storage
Contributors netapp-revathid
Performance information for the reference platform.
Reference platform
ONTAP Select (Premium XL) hardware (per node)
  • FUJITSU PRIMERGY RX2540 M4:
    • Intel® Xeon® Gold 6142b CPU at 2.6 GHz
    • 32 physical cores (16 x 2 sockets), 64 logical
    • 256 GB RAM
    • Drives per host: 24 960GB SSD
    • ESX 6.5U1
Client hardware
  • 5 x NFSv3 IBM 3550m4 clients
Configuration information
  • SW RAID 1 x 9 + 2 RAID-DP (11 drives)
  • 22+1 RAID-5 (RAID-0 in ONTAP) / RAID cache NVRAM
  • No storage efficiency features in use (compression, deduplication, Snapshot copies, SnapMirror, and so on)
The following table lists the throughput measured against read/write workloads on a high availability (HA) pair of ONTAP Select nodes using both software RAID and hardware RAID. Performance measurements were taken using the SIO load-generating tool.
Note These performance numbers are based on ONTAP Select 9.6.
Performance results for a single node (part of a four-node medium instance) ONTAP Select cluster on a direct-attached storage (DAS) SSD, with software RAID and hardware RAID
Description Sequential Read 64KiB Sequential Write 64KiB Random Read 8KiB Random Write 8KiB Random WR/ RD (50/50) 8KiB
ONTAP Select large instance with DAS (SSD) software RAID
2171 MiBps
559 MiBps
954 MiBps
394 MiBps
564 MiBps
ONTAP Select medium instance with DAS (SSD) software RAID
2090 MiBps
592 MiBps
677 MiBps
335 MiBps
441 3MiBps
ONTAP Select medium instance with DAS (SSD) hardware RAID
2038 MiBps
520 MiBps
578 MiBps
325 MiBps
399 MiBps
64K sequential read
Details:
  • SIO direct I/O enabled
  • 2 nodes
  • 2 x data NIC per node
  • 1 x data aggregate per node (2TB hardware RAID), (8TB software RAID)
  • 64 SIO procs, 1 thread per proc
  • 32 volumes per node
  • 1 x files per proc; files are 12000MB each
64K sequential write
Details:
  • 2 nodes
  • 2 x data network interface cards (NICs) per node
  • 1 x data aggregate per node (2TB hardware RAID), (4TB software RAID)
  • 128 SIO procs, 1 thread per proc
  • Volumes per node: 32 (hardware RAID), 16 (software RAID)
  • 1 x files per proc; files are 30720MB each
8K random read
Details:
  • 2 nodes
  • 2 x data NICs per node
  • 64 SIO procs, 8 threads per proc
  • 1 x files per proc; files are 12228MB each
8K random write
Details:
  • 2 nodes
  • 1 x files per proc; files are 8192MB each
8K random 50% write 50% read
Details:
  • 2 nodes
  • 64 SIO proc208 threads per proc
