ONTAP Select
Required information for ONTAP Select installation
Contributors netapp-revathid
As part of preparing to deploy an ONTAP Select cluster in a VMware environment, collect the information required when using the ONTAP Select Deploy administration utility to deploy and configure the cluster.
Some of the information you collect applies to the cluster itself, while other information applies to the individual nodes in the cluster.
Cluster-level information
You must collect information related to the ONTAP Select cluster.
Cluster information Description
Name of the cluster
Unique identifier of the cluster.
Licensing mode
Evaluation or purchased licensing.
IP configuration for the cluster
IP configuration for the clusters and nodes, including:
* Management IP address of the cluster
* Subnet mask
* Default gateway
Host-level information
You must collect information related to each of the nodes in the ONTAP Select cluster.
Name of the host
Unique identifier of the host.
Domain name of the host
Fully qualified domain name of the host.
IP configuration for the nodes
Management IP address for each node in the cluster.
Mirror node
Name of the associated node in the HA pair (multi-node clusters only).
Storage pool
Name of the storage pool that is used.
Storage disks
List of disks if using software RAID.
Serial number
If you are deploying with a purchased license, the unique nine-digit serial number provided by NetApp.
