ONTAP Select VMware vCenter server on ESXi
You must define a vCenter server account and associate it with a role containing the necessary administrative privileges.
You also need the fully qualified domain name or IP address of the vCenter server managing the ESXi hypervisor hosts where ONTAP Select is deployed. |
Administrative privileges
The minimum administrative privileges needed to create and manage an ONTAP Select cluster are presented below.
Datastore
Allocate space
Browse datastore
Low level file operations
Update virtual machine files
Update virtual machine metadata
Host
- Configuration
Network configuration
System management
- Local operations
Create virtual machine
Delete virtual machine
Reconfigure virtual machine
Network
Assign network
Virtual machine
- Configuration
All privileges in the category.
- Interaction
- Inventory
- Provisioning
vApp
Related information
Learn about VMware vSphere privileges for vSAN ESA in vCenter
