ONTAP Select
ONTAP Select VMware vCenter server on ESXi
Contributors netapp-revathid
You must define a vCenter server account and associate it with a role containing the necessary administrative privileges.
Note You also need the fully qualified domain name or IP address of the vCenter server managing the ESXi hypervisor hosts where ONTAP Select is deployed.
Administrative privileges
The minimum administrative privileges needed to create and manage an ONTAP Select cluster are presented below.
Datastore
  • Allocate space
  • Browse datastore
  • Low level file operations
  • Update virtual machine files
  • Update virtual machine metadata
Host
Configuration
  • Network configuration
  • System management
Local operations
  • Create virtual machine
  • Delete virtual machine
  • Reconfigure virtual machine
Network
  • Assign network
Virtual machine
Configuration
All privileges in the category.
Interaction
Inventory
Provisioning
vApp
