ONTAP Select
Considerations for sizing an ONTAP Select Capacity Pools license
The licensed capacity for a Capacity Pool license is in full TB amounts, with a minimum of 2 TB. You calculate the licensed capacity by multiplying the amount of usable space by the overhead factor. The overhead factor differs between a single-node and multi-node (HA-pair based) clusters:
  • Overhead factor for single-node clusters is 1.13
  • Overhead factor for multi-node clusters is 2.67
You need to calculate the licensed capacity based on the usable space to ensure you have enough for your deployment.
Description Single-node HA pair or mix of HA pair and single-node
Usable space
20 TB
10 TB per single-node cluster
20 TB for HA pair
Licensed space
23 TB
(20 x 1.13 = 22.6, round up to next full TB)
54 TB
(20 x 2.67 = 53.4, round up to next full TB)
Maximum usable space per node
Note: The maximum managed space per node or HA pair is 400 TB
353 TB
(400 / 1.13)
Per single-node in a cluster:
149 TB (400 / 2.67)
Per HA pair in a cluster:
298 TB (2 x 149)
