ONTAP Select
Acquire an ONTAP Select Capacity Pool license
You must acquire a license file for each Capacity Pool used by the ONTAP Select nodes. The license file defines the storage capacity and expiration for the pool. It is locked to the License Manager through a combination of the unique license serial number assigned by NetApp and the License Lock ID associated with the Deploy instance.
Before you begin
  • You must have the nine-digit license serial number assigned to the Capacity Pool by NetApp.
  • You should wait at least 24 hours after the shipped date of your purchase order before acquiring a license file.
  • You have reviewed the considerations for sizing a Capacity Pools license.
About this task
You must perform this task for each Capacity Pool used by the ONTAP Select nodes.
Steps
  1. Log in to the NetApp Support site.
  2. Select Systems > Software Licenses.
  3. Type the license serial number for the Capacity Pool and select Go!.
  4. On the license details page, navigate to the Product Details column.
  5. Select Get NetApp License File on the appropriate row.
  6. Type the License Lock ID for your ONTAP Select Deploy instance and select Submit.
  7. Select the appropriate delivery method and select Submit.
  8. Select OK on the delivery confirmation window.
After you finish
You must upload the license file to the Deploy administration utility before an ONTAP Select node can use the Capacity Pool.
