ONTAP Select
Manage ONTAP Select licenses
There are several related tasks you can perform as part of administering the ONTAP Select licenses.
Manage the Capacity Tier licenses
You can add, edit, and delete ONTAP Select Capacity Tier licenses as needed.
Steps
  1. Sign in to the Deploy utility through the web interface using the administrator account.
  2. Select the Administration tab at the top of the page.
  3. Select Licenses and select Capacity Tier.
  4. Optionally select Filter and to limit the licenses displayed.
  5. To replace an existing license; select a license, select Options, and select Update.
  6. To add a new license, select Add at the top of the page and then select Upload License(s) and select a license file from your local workstation.
Manage the Capacity Pool licenses
You can add, edit, and delete ONTAP Select Capacity Pool licenses as needed.
Steps
  3. Select Licenses and select Capacity Pools.
  4. Optionally, select Filter and to limit the licenses displayed.
  5. Optionally, select a license and select Options to manage an existing license.
  6. Add a new license or renew an existing license:
    Add new license
    To add a new license, select Add at the top of the page.
    Renew existing license
    To renew an existing license:
    1. Select Options on an existing license.
    2. Select Upload License(s).
    3. Select a license file from your local workstation.
  7. To see a list of the capacity pools:
    1. Select Summary.
    2. Select and expand a pool to see the clusters and nodes leasing storage from the pool.
    3. View the current status of the license under License Information.
    4. You can change the duration of the leases issued for the pool under Lease expiration.
  8. To see a list of the clusters:
    1. Select Details.
    2. Select and expand the cluster to see storage utilization.
Reinstall a Capacity Pool license
Every active Capacity Pool license is locked to a specific License Manager instance, which is contained within an instance of the Deploy administration utility. If you are using a Capacity Pool license and then restore or recover the Deploy instance, the original license is no longer valid. You must generate a new capacity license file, and then install the license to the new Deploy instance.
Before you begin
  • Determine all the Capacity Pool licenses used by the original Deploy instance.
  • If you restore a backup as part of creating the new Deploy instance, determine if the backup is current and up-to-date.
  • Locate the ONTAP Select nodes that were most recently created by the original Deploy instance (only if an up-to-date backup from the original Deploy instance is not restored to the new Deploy instance).
  • Restore or recreate the Deploy instance
About this task
At a high level, this task is composed of three parts. You must regenerate and install all the Capacity Pool licenses used by the Deploy instance. After all the licenses have been reinstalled to the new Deploy instance, you can reset the serial sequence number if needed. Finally, if the Deploy IP address has changed, you must update every ONTAP Select node that uses a Capacity Pools license.
Steps
  1. Contact NetApp support and have all the Capacity Pool licenses for the original Deploy instance unbound and unregistered.
  2. Acquire and download a new license file for each of the Capacity Pool licenses.
    See Acquire a Capacity Pool license for more information.
  3. Install the Capacity Pool licenses at the new Deploy instance:
    1. Sign in to the Deploy utility web user interface using the administrator account.
    3. Select Licenses and then select Capacity Pool.
    4. Select Add and then Upload License(s) to select and upload the licenses.
  4. If you created the new Deploy instance without restoring a backup, or you used a backup that was not current and up-to-date, you must update the serial sequence number:
    1. Sign in to the Deploy utility command line interface using the administrator account.
    2. Display the serial number for a node most recently created by the original Deploy instance:
      node show -cluster-name CLUSTER_NAME -name NODE_NAME -detailed
    3. Extract the last eight digits from the twenty-digit node serial number to obtain the last serial sequence number used by the original Deploy instance.
    4. Add 20 to the serial sequence number to create the new serial sequence number.
    5. Set the serial sequence number for the new Deploy instance:
      license-manager modify -serial-sequence SEQ_NUMBER
  5. If the IP address assigned to the new Deploy instance is different than the IP address of the original Deploy instance, you must update the IP address at every ONTAP Select node that uses a Capacity Pools license:
    1. Sign in to the ONTAP command line interface of the ONTAP Select node.
    2. Enter advanced privilege mode:
      set adv
    3. Display the current configuration:
      system license license-manager show
    4. Set the License Manager (Deploy) IP address used by the node:
      system license license-manager modify -host NEW_IP_ADDRESS
Convert an evaluation license to a production license
You can upgrade an ONTAP Select evaluation cluster to use a production Capacity Tier license with the Deploy administration utility.
Before you begin
  • Each node must have enough storage allocated to support the minimum required for a production license.
  • You must have Capacity Tier licenses for each node in the evaluation cluster.
About this task
Performing a modification of the cluster license for a single-node cluster is disruptive. However, this is not the case with a multi-node cluster because the conversion process reboots each node one at a time to apply the license.
Steps
  2. Select the Clusters tab a the top of the page and select the desired cluster.
  3. At the top of the cluster details page, select Click here to modify the cluster license.
    You can also select Modify next to evaluation license in the Cluster Details section.
  4. Select an available production license for each node or upload additional licenses as needed.
  5. Provide the ONTAP credentials and select Modify.
    The license upgrade for the cluster can take several minutes. Allow the process to complete before leaving the page or making any other changes.
After you finish
The twenty-digit node serial numbers originally assigned to each node for the evaluation deployment are replaced by the nine-digit serial numbers from the production licenses used for the upgrade.
Manage an expired Capacity Pool license
Generally, when a license expires, nothing happens. However, you cannot install a different license because the nodes are associated with the expired license. Until you renew the license, you should not do anything that would bring the aggregate offline, such as a reboot or failover operation. The recommended action is to expedite the license renewal.
For more information about ONTAP Select and license renewal, refer to the Licenses, installation, upgrades, and reverts section in the FAQ.
Manage add-on licenses
For the ONTAP Select product, add-on licenses are applied directly within ONTAP and are not managed through ONTAP Select Deploy. See Manage licenses overview (cluster administrators only) and Enable new features by adding license keys for more information.
