ONTAP Select
Deploy an ONTAP Select cluster
You can use the web user interface provided with the ONTAP Select Deploy administration utility to deploy a single-node or multi-node ONTAP Select cluster.
When you create an ONTAP Select cluster using the Deploy utility web interface, you are guided through a specific sequence of steps. The exact process varies depending on whether you deploy a single-node or multi-node cluster.
Step 1: Prepare for the deployment
Prepare for the deployment to make sure it's successful.
Steps
  1. Initial planning.
    Review the Plan and License sections. Based on this review, you can make decisions about the cluster, including:
    • Hypervisor
    • Number of nodes
    • License type
    • Platform size (instance type)
    • ONTAP Select version
  2. Prepare the host.
    You must prepare the hypervisor hosts where the ONTAP Select nodes will run and have the needed storage license files based on your licensing model. To view the preparation requirements:
    1. Sign in to the Deploy web UI.
    2. Select Question mark at the top of the page.
    3. Select Prerequisites.
    4. Scroll down to review the requirements and select OK.
  3. Acquire the license files.
    If you plan to deploy the cluster in a production environment, you must acquire the storage license files based on your licensing model.
  4. Deploy installation and account credentials.
    Install the Deploy administration utility and perform initial configuration. You need to have the password for the Deploy administrator account that was configured as part of the installation process.
  5. Optionally, install earlier ONTAP Select node images.
    By default, the Deploy administration utility contains the most current version of ONTAP Select at the time of release. If you want to deploy clusters using an earlier version of ONTAP Select, you need to add the ONTAP Select image to your Deploy instance.
  6. Learn about the "Getting started" launch page.
    The initial page Getting Started with ONTAP Select Deploy guides you through the multi-step process of creating a cluster. There are five major steps, including:
    • Add licenses
    • Add hosts to inventory
    • Create a cluster
    • Network precheck
    • Deploy the cluster
      Note You can perform the same steps independently by selecting the tabs at the top of the page (Clusters, Hypervisor Hosts, Administration).
  7. Review the network checker.
    If you are deploying a multi-node cluster, you should be familiar with the network checker. You can run the network connectivity checker using the web UI or the CLI.
Step 2: Create a single-node or multi-node cluster
You can use the ONTAP Select Deploy web user interface to deploy a single-node or multi-node ONTAP Select cluster.
Before you begin
Verify that you have installed the Deploy administration and completed the initial configuration (password, AutoSupport, and vCenter).
About this task
An ONTAP Select cluster with one or more nodes is created for a production deployment.
Steps
The steps you follow depend on whether you want to create a single-node cluster or a multi-node cluster. A multi-node cluster can have two, four, six, eight, ten, or twelve nodes.
Single-node cluster
  1. Sign in to the Deploy utility through the web interface using the administrator account (admin).
  2. If the Welcome to ONTAP Select pop-up window is displayed, confirm you have met the configuration prerequisites and select OK.
  3. If the Getting Started cluster launch page is not displayed, select Question mark at the top of the page and select Getting Started.
  4. On the Getting Started page, select Upload, and then select a license from your local workstation and select Open to upload the license.
  5. Select Refresh and confirm the license has been added.
  6. Select Next to add a hypervisor host and then select Add.
    You can add the hypervisor host directly or by connecting to a vCenter server. Provide the appropriate host details and credentials as needed.
  7. Select Refresh and confirm the Type value for the host is ESX or KVM.
    Any account credentials you provide are added to the Deploy credential database.
  8. Select Next to begin the cluster creation process.
  9. In the Cluster Details section, provide all the required information describing the cluster and select Done.
  10. Under Node Setup, provide the node management IP address and select the license for the node; you can upload a new license if needed. You also can change the node name if needed.
  11. Provide the Hypervisor and Network configuration.
    There are three node configurations which define the virtual machine size and available feature set. These instance types are supported by the standard, premium, and premium XL offerings of the purchased license, respectively. The license you select for the node must match or exceed the instance type.
    Select the hypervisor host as well as the management and data networks.
  12. Provide the Storage configuration and select Done.
    You can select the drives based on your platform license level and host configuration.
  13. Review and confirm the configuration of the cluster.
    You can change the configuration by selecting Edit in the applicable section.
  14. Select Next and provide the ONTAP administrator password.
  15. Select Create Cluster to begin the cluster creation process and then select OK in the pop-up window.
    It can take up to 30 minutes for the cluster to be created.
  16. Monitor the multi-step cluster creation process to confirm the cluster is created successfully.
    The page is automatically refreshed at regular intervals.
Multi-node cluster
  2. If the Welcome to ONTAP Select popup window is displayed, confirm that you have met the configuration prerequisites and select OK.
  4. On the Getting Started page, select Upload and select a license from your local workstation and select Open to upload the license. Repeat to add additional licenses.
  5. Select Refresh and confirm the licenses have been added.
  6. Select Next to add all hypervisor hosts and then select Add.
    You can add the hypervisor hosts directly or by connecting to a vCenter server. Provide the appropriate host details and credentials as needed.
  9. In the Cluster Details section, select the desired Cluster Size, provide all the required information describing the clusters, and select Done.
  10. Under Node Setup, provide the node management IP addresses and select the licenses for each node; you can upload a new license if needed. You also can change the node names if needed.
    There are three node configurations which define the virtual machine size and available feature set. These instance types are supported by the standard, premium, and premium XL offerings of the purchased license, respectively. The license you select for the nodes must match or exceed the instance type.
    Select the hypervisor hosts as well as the management, data, and internal networks.
  14. Select Next and run the Network Precheck by selecting Run. This validates that the internal network selected for ONTAP cluster traffic is functioning correctly.
  15. Select Next and provide the ONTAP administrator password.
  16. Select Create Cluster to begin the cluster creation process, and then select OK in the popup window.
    It can take up to 45 minutes for the cluster to be created.
  17. Monitor the multi-step cluster creation process to confirm that the cluster is created successfully.
Step 3: Complete the deployment
Tip
If the cluster creation operation is initiated but fails to complete, the ONTAP administrative password you define might not be applied. If this occurs, you can determine the temporary administrative password for the ONTAP Select cluster by using the following CLI command:
(ONTAPdeploy) !/opt/netapp/tools/get_cluster_temp_credentials --cluster-name my_cluster
