ONTAP Select
Platform license offerings for ONTAP Select
Contributors netapp-revathid
You can purchase an ONTAP Select Capacity Tier or Capacity Pool license in the standard, premium, or premium XL level. These license offerings determine the capabilities of the hosts where you deploy ONTAP Select.
What a platform license offering provides
A specific license offering determines the capabilities of the hypervisor host in two areas:
  • Instance type (CPU, memory)
  • Additional features
The license offerings are arranged in an ascending order of capabilities from standard to premium XL. In general, the license option you choose grants you the capabilities of that level and all lower levels. For example, the premium level provides the capabilities of both premium and standard.
The following table compares the capabilities for the standard, premium, and premium XL license offerings.
License supports …​ Standard Premium Premium XL
Instance type
Small only
Small or medium
Small, medium, or large
Hard disk drives (HDD) in a …​
Hardware RAID configuration
Yes
Yes
Yes
vNAS configuration
Yes
Yes
Yes
Solid state drives (SSDs) in a …​
No
Yes
Yes
Software RAID configuration
No
Yes
Yes
vNAS configuration
Yes
Yes
Yes
NVMe drives in a …​
No
No
Yes
No
No
Yes
vNAS configuration
Yes
Yes
Yes
MetroCluster SDS
No
Yes
Yes
Note Kernel-Based Virtual Machines (KVM) do not support the large instance type.
Compare hardware support for platform license offerings
The standard, premium, and premium XL license offerings support a wide range of hardware and software. For current information on hardware and software versions, refer to the Interoperability Matrix Tool.
Core item
Core item type
Host protocols
NFS, SMB/CIFS, iSCSI, and NVMe over TCP
Deployment options
Single node
Two-node cluster (HA pair)
Four, six, eight, ten, or twelve-node cluster
Supported capacity (per node)
Up to 400TB raw data (ESXi and KVM)
Hardware
Hardware type
Instance size
Small
Medium
Large
CPU family
Intel Xeon E5-26xx v3 (Haswell) or later
AMD EPYC Embedded 9004 or later and 8004
ONTAP Select CPU / memory
4 virtual CPUs (vCPUs) / 16GB of RAM
8 vCPUs / 64GB of RAM
16 vCPUs / 128GB of RAM
Host CPU / memory minimum requirements 1
6 cores / 24GB of RAM
10 cores / 72GB of RAM
18 cores / 136GB of RAM
Network (per node)
Minimum of two 1GbE ports for a single node cluster
Minimum of four 1GbE ports for a two-node cluster (HA pair)
Minimum of two 10GbE ports for a four, six, eight, ten, or twelve-node cluster
1 Assumes two cores and 8GB of RAM for the hypervisor.
Storage type
The following table provides the minimum license type required for the specified storage.
Storage type
License type
Standard
Premium
Premium XL
Instance size
Small
Small and medium
Small, medium, and large
Local DAS with hardware RAID controller
8 - 60 drives
8 - 60 drives
8 - 60 drives
HDD (SAS, NL-SAS, SATA)
Not applicable
4 – 60 drives
4 – 60 drives
SSD (SAS)
Not applicable
4 – 60 drives (SSD only)
Local DAS with software RAID
Not applicable
Applicable
4 - 14 drives (NVMe only)
External arrays 1
Datastores hosted on external arrays are connected through FC, FCoE, iSCSI, and NFS (NFS isn't supported for KVM). These datastores provide high availability and resilience.
1 External array protocol support reflects networked storage connectivity.
Software
Software type
Hypervisor support (VMware)
VMware vSphere 9.0
VMware vSphere 8.0GA and updates 1 through 3
VMware vSphere 7.0GA and updates 1 through 3C
Hypervisor support (KVM)
Red Hat Enterprise Linux 64-bit (KVM) 10.1, 10.0, 9.7, 9.6, 9.5, 9.4, 9.3, 9.2, 9.1, 9.0, 8.8, 8.7, and 8.6
Rocky Linux (KVM) 10.1, 10.0, 9.7, 9.6, 9.5, 9.4, 9.3, 9.2, 9.1, 9.0, 8.9, 8.8, 8.7, and 8.6
Management software
NetApp Active IQ Unified Manager management suite
ONTAP Select Deploy Utility
SnapCenter (optional)
What's next?
Learn about purchasing an ONTAP Select license
