ONTAP Select installation and deployment workflow
You can use the following workflow to deploy and administer an ONTAP Select cluster.
Review the planning requirements for your ONTAP Select nodes, storage, networking, and hypervisor environment. Preparing your environment in advance helps you avoid deployment issues.
Install the utility that you use to deploy and manage ONTAP Select clusters.
Purchase and apply the licenses needed for your production deployment. You can choose between the Capacity Tiers and Capacity Pools licensing models.
Deploy an ONTAP Select cluster using the ONTAP Select Deploy administration utilityUse the Deploy utility to create your ONTAP Select cluster:
Administer your ONTAP Select cluster using the same management tools and interfaces you use for other ONTAP clusters.
