ONTAP Select
ONTAP Select VMware hypervisor and hardware considerations
Contributors netapp-revathid
There are several hardware requirements and planning issues you should consider related to the VMware environment.
Hypervisor requirements
There are several requirements related to the hypervisor where ONTAP Select runs.
Note You should review the ONTAP Select Release Notes for any additional known restrictions or limitations.
VMware licensing
To deploy an ONTAP Select cluster, your organization must have a valid VMware vSphere license for the hypervisor hosts where ONTAP Select runs. You should use the licenses that are appropriate for your deployment.
Software compatibility
You can deploy ONTAP Select on KVM and ESXi hypervisors.
KVM
ONTAP Select supports the following KVM hypervisor versions:
  • KVM on Red Hat Enterprise Linux (RHEL) 10.1, 10.0, 9.7, 9.6, 9.5, 9.4, 9.2, 9.1, 9.0, 8.8, 8.7, and 8.6
  • KVM on Rocky Linux 10.1, 10.0, 9.7, 9.6, 9.5, 9.4, 9.3, 9.2, 9.1, 9.0, 8.9, 8.8, 8.7, and 8.6
ESXi
ONTAP Select supports the following ESXi hypervisor versions:
  • VMware ESXi 9.0
  • VMware ESXi 8.0 U3
  • VMware ESXi 8.0 U2
  • VMware ESXi 8.0 U1 (build 21495797)
  • VMware ESXi 8.0 GA (build 20513097)
Note NetApp supports ONTAP Select on the identified versions of ESXi as long as VMware also continues to support the same versions.
Note ESXi 7.0 GA reached end of availability status. If you have ONTAP Select clusters with this version, you must upgrade to the supported versions as per the Interoperability Matrix Tool (IMT).
VMware vCenter and standalone ESXi hosts
If an ESXi hypervisor host is managed by a vCenter server, you must register the host to the Deploy administration utility using the vCenter credentials. You cannot register the host as a standalone host using the ESXi credentials.
Core hardware requirements
The physical hypervisor host where you deploy ONTAP Select must meet several hardware requirements. You can choose any platform for the hypervisor host, as long as it meets the minimum hardware requirements. The following vendors provide supported hardware platforms: Cisco, Dell, HP, Fujitsu, Lenovo, and Supermicro.
ONTAP Select supports CPU models based on Intel Xeon Sandy Bridge and Advanced Micro Devices (AMD) processors.
Refer to the Interoperability Matrix Tool for more information.
Basic hardware requirements
There are several common hardware requirements that apply to all platforms regardless of the node instance type or license offering.
Processor
The supported microprocessors include Intel Xeon server processors and AMD processors.
Refer to Intel Xeon Processors and AMD EPYC Server CPUs for more information.
Ethernet configuration
There are several supported Ethernet configurations based on the cluster size.
Cluster size Minimum requirements Recommended requirements
Single node cluster
2 x 1GbE
2 x 10GbE
Two-node cluster or MetroCluster SDS
4 x 1GbE or 1 x 10GbE
2 x 10GbE
Four, six, eight, ten, or twelve-node cluster
2 x 10GbE
4 x 10GbE or 2 x 25/40GbE
Additional hardware requirements based on the instance type
There are several additional hardware requirements based on the node instance type.
Node size CPU cores Memory Required platform license offering
Small
Six physical cores or greater, with four reserved for ONTAP Select
24GB or greater, with 16GB reserved for ONTAP Select
Standard, premium, or premium XL
Medium
Ten physical cores or greater, with eight reserved for ONTAP Select
72GB or greater, with 64GB reserved for ONTAP Select
Premium or premium XL
Large
Eighteen physical cores or greater, with sixteen reserved for ONTAP Select
136GB or greater, with 128GB reserved for ONTAP Select
Premium XL
Note There are additional disk requirements based on the platform license. See Storage and RAID for more information.
Related information
Learn about the platform license offerings for ONTAP Select
