AutoSupport severity types
Contributors netapp-ivanad
AutoSupport messages have severity types that help you understand the purpose of each message—​for example, to draw immediate attention to an emergency problem, or only to provide information.
Messages have one of the following severities:
  • Alert: Alert messages indicate that a next-higher level event might occur if you do not take some action.
    You must take an action against alert messages within 24 hours.
  • Emergency: Emergency messages are displayed when a disruption has occurred.
    You must take an action against emergency messages immediately.
  • Error: Error conditions indicate what might happen if you ignore.
  • Notice: Normal but significant condition.
  • Info: Informational message provides details about the issue, which you can ignore.
  • Debug: Debug-level messages provide instructions you should perform.
If your internal support organization receives AutoSupport messages through email, the severity appears in the subject line of the email message.
