Manage Kerberos interface services with System Manager - ONTAP 9.7 and earlier
Contributors netapp-aoife
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to manage Kerberos interface services.
Edit Kerberos configuration
You can use System Manager to enable Kerberos and to edit a Kerberos configuration that is associated with a storage virtual machine (SVM),which enables the SVM to use Kerberos security services for NFS.
Before you begin
  • You must have at least one Kerberos realm configured at the SVM level.
  • You must have a minimum of two data LIFs on the SVM.
    One data LIF is used by the Service Principal Name (SPN) for both the UNIX and CIFS-related Kerberos traffic. The other data LIF is used for accessing non-Kerberos traffic.
    Note
    A CIFS server is not required for basic NFS Kerberos access. A CIFS server is required for multiprotocol access or when using Active Directory as an LDAP server for name mapping purposes.
About this task
If you are using Microsoft Active Directory Kerberos, the first 15 characters of any SPNs that are used in the domain must be unique. Microsoft Active Directory has a limitation for SPNs of 15 characters maximum and does not allow duplicate SPNs.
Steps
  1. Click Storage > SVMs.
  2. Select the SVM, and then click SVM Settings.
  3. In the Services pane, click Kerberos Interface.
  4. In the Kerberos Interface window, select the interface, and then click Edit.
  5. In the Edit Kerberos Configuration dialog box, make the required changes, and then click OK.
You can use the Kerberos Interface window to enable Kerberos and to edit the Kerberos configuration for storage virtual machines (SVMs).
Command buttons
  • Edit
    Opens the Edit Kerberos Configuration dialog box, which you can use to enable Kerberos and to edit the Kerberos configuration associated with the SVM.
  • Refresh
    Updates the information in the window.
Kerberos Interface list
Provides details about the Kerberos configuration.
  • Interface Name
    Specifies the logical interfaces associated with the Kerberos configuration for SVMs.
  • Service Principal Name
    Specifies the Service Principal Name (SPN) that matches the Kerberos configuration.
  • Realm
    Specifies the name of the Kerberos realm associated with the Kerberos configuration.
  • Kerberos Status
    Specifies whether Kerberos is enabled.
Related information
