Quota limits
Contributors netapp-ivanad
You can apply a disk space limit or limit the number of files for each quota type. If you do not specify a limit for a quota, none is applied.
Quotas can be soft or hard. Soft quotas cause Data ONTAP to send a notification when specified limits are exceeded, and hard quotas prevent a write operation from succeeding when specified limits are exceeded.
Hard quotas impose a hard limit on system resources; any operation that would result in exceeding the limit fails. The following settings create hard quotas:
  • Disk Limit parameter
  • Files Limit parameter
Soft quotas send a warning message when resource usage reaches a certain level, but do not affect data access operations, so you can take appropriate action before the quota is exceeded. The following settings create soft quotas:
  • Threshold for Disk Limit parameter
  • Soft Disk Limit parameter
  • Soft Files Limit parameter
Threshold and Soft Disk quotas enable administrators to receive more than one notification about a quota. Typically, administrators set the Threshold for Disk Limit to a value that is only slightly smaller than the Disk Limit, so that the threshold provides a "final warning" before writes start to fail.
  • Disk space hard limit
    Disk space limit applied to hard quotas.
  • Disk space soft limit
    Disk space limit applied to soft quotas.
  • Threshold limit
    Disk space limit applied to threshold quotas.
  • Files hard limit
    The maximum number of files on a hard quota.
  • Files soft limit
    The maximum number of files on a soft quota.
