Roles and permissions
Contributors netapp-ivanad
The cluster administrator can restrict a user’s access to only a specified set of commands by creating a restricted access-control role and then assigning the role to a user.
You can manage access-control roles in the following ways:
  • By creating an access-control role, and then specifying the command or command directory that the role’s users can access.
  • By controlling the level of access that the role has for the command or command directory, and then specifying a query that applies to the command or command directory.
  • By modifying an access-control role’s access to a command or command directory.
  • By displaying information about access-control roles, such as the role name, the command or command directory that a role can access, the access level, and the query.
  • By deleting an access-control role.
  • By restricting a user’s access to only a specified set of commands.
  • By displaying ONTAP APIs and their corresponding command-line interface (CLI) commands.
