Types of SVMs
Contributors netapp-ivanad
A cluster consists of four types of SVMs, which help in managing the cluster and its resources and data access to the clients and applications.
A cluster contains the following types of SVMs:
  • Admin SVM
    The cluster setup process automatically creates the admin SVM for the cluster. The admin SVM represents the cluster.
  • Node SVM
    A node SVM is created when the node joins the cluster, and the node SVM represents the individual nodes of the cluster.
  • System SVM (advanced)
    A system SVM is automatically created for cluster-level communications in an IPspace.
  • Data SVM
    A data SVM represents the data serving SVMs. After the cluster setup, a cluster administrator must create data SVMs and add volumes to these SVMs to facilitate data access from the cluster.
    A cluster must have at least one data SVM to serve data to its clients.
Note
Unless otherwise specified, the term SVM refers to a data (data-serving) SVM.In the CLI, SVMs are displayed as Vservers.
