Array LUNs window
Contributors netapp-ivanad
The Array LUNs window enables you to assign ownership to your array LUNs and to add them to an aggregate.
The Array LUNs link in the left navigation pane is displayed only if there are any spare array LUNs, or if the V_StorageAttach license is installed.
Command buttons
  • Assign
    Enables you to assign or reassign the ownership of array LUNs to a node.
  • Zero Spares
    Erases all the data, and formats the spare array LUNs and disks.
  • Refresh
    Updates the information in the window.
Array LUN list
Displays information such as the name, state, and vendor for each array LUN.
  • Name
    Specifies the name of the array LUN.
  • State
    Specifies the state of the array LUN.
  • Vendor
    Specifies the name of the vendor.
  • Used Space
    Specifies the space used by the array LUN.
  • Total Size
    Specifies the size of the array LUN.
  • Container
    Specifies the aggregate to which the array LUN belongs.
  • Node name
    Specifies the name of the node to which the array LUN belongs.
  • Home owner
    Displays the name of the home node to which the array LUN is assigned.
  • Current owner
    Displays the name of the node that currently owns the array LUN.
  • Array name
    Specifies the name of the array.
  • Pool
    Displays the name of the pool to which the selected array LUN is assigned.
Details area
The area below the Array LUNs list displays detailed information about the selected array LUN.
