DNS/DDNS Services window
Contributors netapp-ivanad
The DNS/DDNS Services window enables you to view and edit the current DNS and DDNS settings for your system.
Command buttons
  • Edit
    Opens the Edit DNS/DDNS Settings dialog box, which you can use to add or modify DNS or DDNS details. You can also enable or disable DDNS.
  • Refresh
    Updates the information in the window.
Related information
