Events window
Contributors netapp-ivanad
You can use the Events window to view the event log and event notifications.
Command buttons
  • Refresh
    Updates the information in the window.
Events list
  • Time
    Displays the time when the event occurred.
  • Node
    Displays the node and the cluster on which the event occurred.
  • Severity
    Displays the severity of the event. The possible severity levels are:
    • Emergency
      Specifies that the event source unexpectedly stopped, and the system experienced unrecoverable data loss. You must take corrective action immediately to avoid extended downtime.
    • Alert
      Specifies that the event source has an alert, and action must be taken to avoid downtime.
    • Critical
      Specifies that the event source is critical, and might lead to service disruption if corrective action is not taken immediately.
    • Error
      Specifies that the event source is still performing, and a corrective action is required to avoid service disruption.
    • Warning
      Specifies that the event source experienced an occurrence that you must be aware of. Events of this severity might not cause service disruption; however, corrective action might be required.
    • Notice
      Specifies that the event source is normal, but the severity is a significant condition that you must be aware of.
    • Informational
      Specifies that the event source has an occurrence that you must be aware of. No corrective action might be required.
    • Debug
      Specifies that the event source includes a debugging message.
    By default, the alert severity type, emergency severity type, and the error severity type are displayed.
  • Source
    Displays the source of the event.
  • Event
    Displays the description of the event.
Details area
Displays the event details, including the event description, message name, sequence number, message description, and corrective action for the selected event.
