Guidelines for using deduplication
Contributors netapp-ivanad
You must remember certain guidelines about system resources and free space when using deduplication.
The guidelines are as follows:
  • If you have a performance-sensitive solution, you must carefully consider the performance impact of deduplication and measure the impact in a test setup before using deduplication.
  • Deduplication is a background process that consumes system resources while it is running.
    If the data does not change very often in a FlexVol volume, it is best to run deduplication less frequently. Multiple concurrent deduplication operations running on a storage system lead to a higher consumption of system resources.
  • You must ensure that sufficient free space exists for deduplication metadata in the volumes and aggregates.
  • If deduplication is used on the source volume, you must use deduplication on the destination volume.
  • You must use automatic mode when possible so that deduplication runs only when significant additional data has been written to each FlexVol volume.
  • You must run deduplication before creating a Snapshot copy to obtain maximum savings.
  • You must set the Snapshot reserve to greater than 0 if Snapshot copies are used.
