Hardware Cache window
Contributors netapp-ivanad
You can use the Hardware Cache window to enable or disable Flash Cache modules for a storage system that has a Flash Cache module installed. You can also view the read-workload statistics.
Module Information
  • Storage system name
    The name of the storage system that has a Flash Cache module installed displays under the graphic.
  • Enable/Disable toggle button
    Move the toggle button to enable or disable the module.
  • Size
    The size of the module in gigabytes. If there are multiple Flash Cache module cards, the total cache size from all of the cards is displayed.
    Note
    The Flash Cache module size that is displayed differs from the actual size for the following reasons: - System Manager reports only the usable capacity that is provided by ONTAP. - A portion of the total capacity is reserved for storing metadata.
  • Model Names
    The model names of the modules.
  • System Read Latency
    Displays the average read latency in milliseconds.
Cache Read Workload
Indicates storage system performance by displaying a graph specifying the rate of the read workload that is served by the disks and the Flash Cache module.
