iSCSI window
Contributors netapp-ivanad
You can use the iSCSI window to start or stop the iSCSI service, change a storage system iSCSI node name, and create or change the iSCSI alias of a storage system. You can also add or change the initiator security setting for an iSCSI initiator that is connected to your storage system.
Tabs
  • Service
    You can use the Service tab to start or stop the iSCSI service, change a storage system iSCSI node name, and create or change the iSCSI alias of a storage system.
  • Initiator Security
    You can use the Initiator Security tab to add or change the initiator security setting for an iSCSI initiator that is connected to your storage system.
Command buttons
  • Edit
    Opens Edit iSCSI Service Configurations dialog box, which enables you to change iSCSI node name and iSCSI alias of the storage system.
  • Start
    Starts the iSCSI service.
  • Stop
    Stops the iSCSI service.
  • Refresh
    Updates the information in the window.
Details area
The details area displays information about the status of the iSCSI service, iSCSI target node name, and iSCSI target alias. You can use this area to enable or disable the iSCSI service on a network interface.
Related information
