Kerberos Interface window
Contributors netapp-ivanad
You can use the Kerberos Interface window to enable Kerberos and to edit the Kerberos configuration for storage virtual machines (SVMs).
Command buttons
  • Edit
    Opens the Edit Kerberos Configuration dialog box, which you can use to enable Kerberos and to edit the Kerberos configuration associated with the SVM.
  • Refresh
    Updates the information in the window.
Kerberos Interface list
Provides details about the Kerberos configuration.
  • Interface Name
    Specifies the logical interfaces associated with the Kerberos configuration for SVMs.
  • Service Principal Name
    Specifies the Service Principal Name (SPN) that matches the Kerberos configuration.
  • Realm
    Specifies the name of the Kerberos realm associated with the Kerberos configuration.
  • Kerberos Status
    Specifies whether Kerberos is enabled.
