LDAP Configuration window
Contributors netapp-ivanad
You can use the LDAP Configuration window to edit or delete active LDAP clients at the storage virtual machine (SVM) level.
Command buttons
  • Edit
    Opens the Active LDAP Client dialog box, which enables you to edit the properties of the active LDAP client, such as Active Directory domain servers and preferred Active Directory servers.
  • Delete
    Opens the Delete Active LDAP Client dialog box, which enables you to delete the active LDAP client.
  • Refresh
    Updates the information in the window.
LDAP Configuration area
Displays the details about the active LDAP client.
  • LDAP client name
    Displays the name of the active LDAP client.
  • Active Directory Domain Servers
    Displays the Active Directory domain for the active LDAP client.
  • Preferred Active Directory Servers
    Displays the preferred Active Directory server for the active LDAP client.
