LDAP window
Contributors netapp-ivanad
You can use the LDAP window to view LDAP clients for user authentication, file access authorization, and user search, and to map services between NFS and CIFS at the cluster level.
Command buttons
  • Add
    Opens the Create LDAP Client dialog box, which enables you to create and configure LDAP clients.
  • Edit
    Opens the Edit LDAP Client dialog box, which enables you to edit LDAP client configurations. You can also edit active LDAP clients.
  • Delete
    Opens the Delete LDAP Client(s) dialog box, which enables you to delete LDAP client configurations. You can also delete an active LDAP client.
  • Refresh
    Updates the information in the window.
LDAP client list
Displays (in tabular format) details about LDAP clients.
  • LDAP Client Configuration
    Displays the name of the LDAP client configuration that you specified.
  • Storage Virtual Machine
    Displays the name of the storage virtual machine (SVM) for each LDAP client configuration.
  • Schema
    Displays the schema for each LDAP client.
  • Minimum Bind Level
    Displays the minimum bind level for each LDAP client.
  • Active Directory Domain
    Displays the Active Directory domain for each LDAP client configuration.
  • LDAP Servers
    Displays the LDAP server for each LDAP client configuration.
  • Preferred Active Directory Servers
    Displays the preferred Active Directory server for each LDAP client configuration.
