Name Mapping window
Contributors netapp-ivanad
You can use the Name Mapping window to specify the name mapping entries to map users from different platforms.
Name Mappings
You can create and use name mappings to map your UNIX users to Windows users, Windows users to UNIX users, or Kerberos users to UNIX users.
Command buttons
  • Add
    Opens the Add Name Mapping Entry dialog box, which enables you to create a name mapping on storage virtual machines (SVMs).
  • Edit
    Opens the Edit Name Mapping Entry dialog box, which enables you to edit a name mapping on SVMs.
  • Delete
    Opens the Delete Name Mapping Entries dialog box, which enables you to delete a name mapping entry.
  • Swap
    Opens the Swap Name Mapping Entries dialog box, which enables you to interchange positions of the two selected name mapping entries.
  • Refresh
    Updates the information in the window.
Name mappings list
  • Position
    Specifies the name mapping’s position in the priority list. Name mappings are applied in the order in which they occur in the priority list.
  • Pattern
    Specifies the user name pattern that must be matched.
  • Replacement
    Specifies the replacement pattern for the user name.
  • Direction
    Specifies the direction of the name mapping. Possible values are krb_unix for a Kerberos-to-UNIX name mapping, win_unix for a Windows-to-UNIX name mapping, and unix_win for a UNIX-to-Windows name mapping.
Command buttons
  • Add
    Opens the Add Group Mapping Entry dialog box, which enables you to create a group mapping on SVMs.
  • Edit
    Opens the Edit Group Mapping Entry dialog box, which enables you to edit the group mapping on SVMs.
  • Delete
    Opens the Delete Group Mapping Entries dialog box, which enables you to delete a group mapping entry.
  • Swap
    Opens the Swap Group Mapping Entries dialog box, which enables you to interchange positions of the two selected group mapping entries.
  • Refresh
Group mappings list
  • Position
    Specifies the group mapping’s position in the priority list. Group mappings are applied in the order in which they occur in the priority list.
  • Pattern
  • Replacement
    Specifies the replacement pattern for the user names.
  • Direction
    Specifies the direction of the group mapping. Possible values are krb_unix for a Kerberos-to-UNIX group mapping, win_unix for a Windows-to-UNIX group mapping, and unix_win for a UNIX-to-Windows group mapping.
