NFS window
Contributors netapp-ivanad
You can use the NFS window to display and configure your NFS settings.
  • Server Status
    Displays the status of the NFS service. The service is enabled if the NFS protocol is configured on the storage virtual machine (SVM).
    Note
    If you have upgraded to ONTAP 8.3 or later from an NFS-enabled storage system running Data ONTAP 8.1.x, the NFS service is enabled in ONTAP 8.3 or later. However, you must enable support for NFSv3 or NFSv4 because NFSv2 is no longer supported.
Command buttons
  • Enable
    Enables the NFS service.
  • Disable
    Disables the NFS service.
  • Edit
    Opens the Edit NFS Settings dialog box, which enables you to edit NFS settings.
  • Refresh
    Updates the information in the window.
Related information
