Nodes window
Contributors netapp-ivanad
You can use the Nodes window to view the details of the nodes in a cluster.
Command buttons
  • Initialize ComplianceClock
    Initializes the ComplianceClock of the selected node to the current value of the system clock.
  • Refresh
    Updates the information in the window.
Nodes list
  • Name
    Displays the name of the node.
  • State
    Displays the state of the node (whether the node is up or down).
  • Up Time
    Displays the duration for which the node is up.
  • ONTAP Version
    Displays the ONTAP version that is installed on the node.
  • Model
    Displays the platform model number of the node.
  • System ID
    Displays the ID of the node.
  • Serial No
    Displays the serial number of the node.
Details area
Displays detailed information about the selected node.
  • Details tab
    Displays information related to the selected node such as the name of the node, the state of the node, and the duration for which the node is up.
  • Performance tab
    Displays the throughput, IOPS, and latency of the selected node.
    Changing the client time zone or the cluster time zone impacts the performance metrics graphs. You should refresh your browser to view the updated graphs.
