Prerequisites for cluster peering
Contributors netapp-ivanad
Before you set up cluster peering, you should confirm that the connectivity, port, IP address, subnet, firewall, and cluster-naming requirements are met.
Connectivity requirements
Every intercluster LIF on the local cluster must be able to communicate with every intercluster LIF on the remote cluster.
Although it is not required, it is typically simpler to configure the IP addresses used for intercluster LIFs in the same subnet. The IP addresses can reside in the same subnet as data LIFs, or in a different subnet. The subnet used in each cluster must meet the following requirements:
  • The subnet must belong to the broadcast domain that contains the ports that are used for intercluster communication.
Intercluster LIFs can have an IPv4 address or an IPv6 address.
Note
ONTAP 9 enables you to migrate your peering networks from IPv4 to IPv6 by optionally allowing both protocols to be present simultaneously on the intercluster LIFs. In earlier releases, all intercluster relationships for an entire cluster were either IPv4 or IPv6. This meant that changing protocols was a potentially disruptive event.
Port requirements
You can use dedicated ports for intercluster communication, or share ports used by the data network. Ports must meet the following requirements:
  • All ports that are used to communicate with a given remote cluster must be in the same IPspace.
    You can use multiple IPspaces to peer with multiple clusters. Pair-wise full-mesh connectivity is required only within an IPspace.
  • The broadcast domain that is used for intercluster communication must include at least two ports per node so that intercluster communication can fail over from one port to another port.
    Ports added to a broadcast domain can be physical network ports, VLANs, or interface groups (ifgrps).
  • All ports must be cabled.
  • All ports must be in a healthy state.
  • The MTU settings of the ports must be consistent.
Firewall requirements
Firewalls and the intercluster firewall policy must allow the following protocols:
  • ICMP service
  • TCP to the IP addresses of all the intercluster LIFs over the ports 10000, 11104, and 11105
  • Bidirectional HTTPS between the intercluster LIFs
The default intercluster firewall policy allows access through the HTTPS protocol and from all IP addresses (0.0.0.0/0). You can modify or replace the policy if necessary.
Related information
