Qtrees window
Contributors netapp-ivanad
You can use the Qtrees window to create, display, and manage information about qtrees.
Command buttons
  • Create
    Opens the Create Qtree dialog box, which enables you to create a new qtree.
  • Edit
    Opens the Edit Qtree dialog box, which enables you to change the security style and to enable or disable oplocks (opportunistic locks) on a qtree.
  • Change Export Policy
    Opens the Export Policy dialog box, which enables you to assign one or more qtrees to new or existing export policies.
  • Delete
    Deletes the selected qtree.
    This button is disabled unless the status of the selected qtree is normal.
  • Refresh
    Updates the information in the window.
Qtree list
The qtree list displays the volume in which the qtree resides and the qtree name.
  • Name
    Displays the name of the qtree.
  • Volume
    Displays the name of the volume in which the qtree resides.
  • Security Style
    Specifies the security style of the qtree.
  • Status
    Specifies the current status of the qtree.
  • Oplocks
    Specifies whether the oplocks setting is enabled or disabled for the qtree.
  • Export Policy
    Displays the name of the export policy to which the qtree is assigned.
Details area
  • Details tab
    Displays detailed information about the selected qtree, such as the mount path of the volume containing the qtree, details about the export policy, and the export policy rules.
Related information
