Quotas window
Contributors netapp-ivanad
You can use the Quotas window to create, display, and manage information about quotas.
Tabs
  • User Defined Quotas
    You can use the User Defined Quotas tab to view details of the quotas that you create and to create, edit, or delete quotas.
  • Quota Report
    You can use the Quota Report tab to view the space and file usage and to edit the space and file limits of quotas that are active.
  • Quota Status on Volumes
    You can use the Quota Status on Volumes tab to view the status of a quota and to turn quotas on or off and to resize quotas.
Command buttons
  • Create
    Opens the Create Quota wizard, which enables you to create quotas.
  • Edit Limits
    Opens the Edit Limits dialog box, which enables you to edit settings of the selected quota.
  • Delete
    Deletes the selected quota from the quotas list.
  • Refresh
    Updates the information in the window.
User Defined Quotas list
The quotas list displays the name and storage information for each quota.
  • Volume
    Specifies the volume to which the quota is applied.
  • Qtree
    Specifies the qtree associated with the quota. “All Qtrees” indicates that the quota is associated with all the qtrees.
  • Type
    Specifies the quota type: user, or group, or tree.
  • User/Group
    Specifies a user or a group associated with the quota. "All Users" indicates that the quota is associated with all the users. "All groups" indicates that the quota is associated with all the groups.
  • Quota Target
    Specifies the type of target that the quota is assigned to. The target can be qtree, user, or group.
  • Space Hard Limit
    Specifies the disk space limit applied to hard quotas.
    This field is hidden by default.
  • Space Soft Limit
    Specifies the disk space limit applied to soft quotas.
  • Threshold
    Specifies the disk space limit applied to threshold quotas.
  • File Hard Limit
    Specifies the maximum number of files in a hard quota.
  • File Soft Limit
    Specifies the maximum number of files in a soft quota.
Details area
The area below the quotas list displays quota details such as the quota error, space usage and limits, and file usage and limits.
Related information
