Roles window
Contributors netapp-ivanad
You can use the Roles window to manage the roles that are associated with user accounts.
Command buttons
  • Add
    Opens the Add Role dialog box, which enables you to create an access-control role and specify the command or command directory that the role’s users can access.
  • Edit
    Opens the Edit Role dialog box, which enables you to add or modify role attributes.
  • Refresh
    Updates the information in the window.
Roles list
The roles list provides a list of roles that are available to be assigned to users.
Role Attributes area
The details area displays the role attributes, such as the command or command directory that the selected role can access, the access level, and the query that applies to the command or command directory.
