Shares window
Contributors netapp-ivanad
You can use the Shares window to manage your shares and to view information about the shares.
Command buttons
  • Create Share
    Opens the Create Share dialog box, which enables you to create a share.
  • Create Home Directory
    Opens the Create Home Directory Share dialog box, which enables you to create a new home directory share.
  • Edit
    Opens the Edit Settings dialog box, which enables you to modify the properties of a selected share.
  • Stop Sharing
    Stops the selected object from being shared.
  • Refresh
    Updates the information in the window.
Shares list
The shares list displays the name and path of each share.
  • Share Name
    Displays the name of the share.
  • Path
    Displays the complete path name of an existing folder, qtree, or volume that is shared. Path separators can be backward slashes or forward slashes, although ONTAP displays all path separators as forward slashes.
  • Home Directory
    Displays the name of the home directory share.
  • Comment
    Displays additional descriptions of the share, if any.
  • Continuously Available Share
    Displays whether the share is enabled for continuous availability. Starting with System Manager 9.6, continuous availability is supported for FlexGroup volumes.
Details area
The area below the shares list displays the share properties and the access rights for each share.
  • Properties
    • Name
    • Oplocks status
      Specifies whether the share uses opportunistic locks (oplocks).
    • Browsable
      Specifies whether the share can be browsed by Windows clients.
    • Show Snapshot
      Specifies whether Snapshot copies can be viewed by clients.
      Specifies whether the share is enabled or disabled for continuous availability. Starting with System Manager 9.6, continuous availability is supported for FlexGroup volumes.
    • Access-Based Enumeration
      Specifies whether access-based enumeration (ABE) is enabled or disabled on the share.
    • BranchCache
      Specifies whether BranchCache is enabled or disabled on the share.
    • SMB Encryption
      Specifies whether data encryption using SMB 3.0 is enabled at the storage virtual machine (SVM) level or at the share level. If SMB encryption is enabled at the SVM level, SMB encryption applies for all of the shares and the value is shown as Enabled (at the SVM level).
    • Previous Versions
      Specifies whether the previous versions can be viewed and restored from the client.
  • Share access control
    Displays the access rights of the domain users, domain groups, local users, and local groups for the share.
Related information
