Snapshot Policies window
Contributors netapp-ivanad
You can use the Snapshot Policies window to manage Snapshot policy tasks, such as adding, editing, and deleting Snapshot policies.
Command buttons
  • Create
    Opens the Create Snapshot Policy dialog box, which enables you to add backup schedules and specify the maximum number of Snapshot copies to be retained in a policy.
  • Edit
    Opens the Edit Snapshot Policy dialog box, which enables you to modify the frequency at which Snapshot copies should be created and the maximum number of Snapshot copies to be retained.
  • Delete
    Opens the Delete dialog box, which enables you to delete the selected Snapshot policy.
  • View as
    Enables you to view the Snapshot policies either as a list or as a tree.
  • Status
    Opens the menu, which you can use to either enable or disable the selected Snapshot policy.
  • Refresh
    Updates the information in the window.
Snapshot policy list
  • Policy/Schedule Name
    Specifies the name of the Snapshot policy and the schedules in the policy.
  • Storage Virtual Machine
    Specifies the name of the storage virtual machine (SVM) to which the Snapshot copies belong.
  • Status
    Specifies the status of the Snapshot policy, which can be Enabled or Disabled.
  • Maximum Snapshots to be retained
    Specifies the maximum number of Snapshot copies to be retained.
  • SnapMirror Label
    Specifies the name of the SnapMirror label attribute of the Snapshot copy generated by the backup schedule.
