SNMP window
Contributors netapp-ivanad
The SNMP window enables you to view the current SNMP settings for your system. You can also change your system’s SNMP settings, enable SNMP protocols, and add trap hosts.
Command buttons
  • Enable/Disable
    Enables or disables SNMP.
  • Edit
    Opens the Edit SNMP Settings dialog box, which enables you to specify the SNMP communities for your storage system and enable or disable traps.
  • Test Trap Host
    Sends a test trap to all the configured hosts to check whether the test trap reaches all the hosts and whether the configurations for SNMP are set correctly.
  • Refresh
    Updates the information in the window.
Details
The details area displays the following information about the SNMP server and host traps for your storage system:
  • SNMP
    Displays whether SNMP is enabled or not.
  • Traps
    Displays if SNMP traps are enabled or not.
  • Location
    Displays the address of the SNMP server.
  • Contact
    Displays the contact details for the SNMP server.
  • Trap host IP Address
    Displays the IP addresses of the trap host.
  • Community Names
    Displays the community name of the SNMP server.
  • Security Names
    Displays the security style for the SNMP server.
Related information
